Derivation of Schwarzschild radius from escape velocity
greypilgrim
Hi,
Is it pure coincidence that if you put ##c=v_e=\sqrt{2GM/R}## in the escape velocity, you end up with the Schwarzschild radius ##R=2GM/c^2##?
The derivation of the escape velocity is purely classical mechanics. It involves ##E_{kin}=mv^2/2## which is incorrect in special relativity even for massive particles and is entirely useless for massless photons.
One could argue that with the constants ##G,M,c## at hand the form of the Schwarzschild radius follows from dimensional analysis, but that doesn't explain why the factor ##2## is present in both derivations.
greypilgrim said:
Hi,
Newtonian escape velocity can be derived without use energy.
That Newtonian escape velocity = c matches SC radius is generally considered a coincidence. Note that in Newtonian mechanics, there is nothing special about c, and nothing preventing a body having escape velocity > c, nor preventing projectiles with v>c that can escape.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
