Mechanical Energy:Potential, kinect, etc.
  • Thread starter Thread starter Patolord
    Mechanical
The discussion revolves around calculating the force exerted by the ground on a 2kg sphere at the bottom of a semi-circular hole. The potential energy at the release point is calculated as 4J, and the weight of the sphere is determined to be 20N. Using conservation of energy, the velocity at point B is found to be 2m/s, leading to a centripetal force requirement of 40N. The total force from the ground is then the sum of the centripetal force and the weight, resulting in 60N. Understanding centripetal force is crucial for solving similar problems involving circular motion.
Patolord
A sphere of mass 2kg is release from point A off the edge of a hole that is represented of as a semi-circle of R=0,2 m.
consider g=10m/s²
What is the force that the ground apply on the sphere when it passes trough point B(bottom of the hole?
Ep=m*g*h
Ec=m*v²/2
Q=m*v
F=m*a
I tried finding the Potential energy of the sphere at point A that is
Ep=2kg*0,2m*10m/s² = 4J
and the weight of the sphere that is 2*10= 20 N
I don't know what to do anymore the velocity at point B i considered 2m/s because of
Ep=Ec=m*v²/2 then V=2m/s
Help?
Image not from actual problem point A would be the left point B where it is on the pic
You can simply find the speed of the sphere when it reaches point B using conservation of energy.Call it v_B. When the sphere is moving in the semi-circle,it needs a centripetal force which at point B is equal to \frac{mv_B^2}{R}. But this centripetal force can be provided only by the circular track and nothing else so your answer is \frac{mv_B^2}{R}.
Likes 1 person
AH thanks the answer is 60N i guess you have to sum that with the weight that is 20N
40 +20 =60 N
but i don't get where mv2/r comes .. i don't have that on my theory
they just gave mv²/2 and m*g*h
You need to understand the centripetal force concepts before solving this problem. You should know that the centripetal force mv^2/r is the net force acting inward toward the center of the circle. So the centripetal force is 40 N inward and is comprised of the net force of the ground normal force acting up
and the weight acting down, the net force
Likes 1 person
Thank you, now i see why couldn't soulve any problems envolving circles xD
