Absolute pressure at the bottom of a container
To calculate the absolute pressure at the bottom of a container filled with water and oil, the correct formula is P = ρgh + P(atmospheric). The user initially attempted to calculate the pressure using an incorrect depth by subtracting the water depth from the oil thickness. It was pointed out that the user also failed to convert centimeters to meters, which is essential for accurate calculations. The correct approach requires adding the pressures from both the water and oil layers without any subtraction. Accurate calculations are crucial to avoid discrepancies in results.
kimlu
A container is filled to a depth of 20.0 cm with water. On top of the water floats a 29.0-cm-thick layer of oil with specific gravity 0.800. What is the absolute pressure at the bottom of the container?
(Answer in Pa)
P= ρgh+ P(atmospheric)
(800)(9.81)(29-20)+101.3x10^3= 171932
Webassign says "Your response differs from the correct answer by more than 10%. Double check your calculations."
Did I substitute something wrong?
Hi kimlu...
You have to calculate pressure at the bottom of the container ,not between the interface of water and oil .
You also seem to have forgotton to convert 'cm' to 'm' .
(Answer in Pa)
Yes.
Why did you subtract the thickness of water from the thickness of oil?
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
