Is this equation solvable for y?
  • Thread starter Thread starter examorph
The equation in question can be simplified to the form y = A - By, where A and B are defined in terms of constants K, P, and n. The user has struggled with manipulating the equation and has been advised that the quadratic formula may be necessary. However, it is suggested that solving for y should be straightforward without an online solver. The response indicates that the solution provided by the online solver may be incorrect, prompting a review of the original equation submitted.
examorph
I have been trying to solve the following equation for the variable y:
https://imageshack.com/i/0r9khg
Where K and P are constants, I tried an online solver which gave me the following result:
https://imageshack.com/i/nq4qm6g
I attempted to solve for this by adding the -1/2(n^2 t^2 y) to both sides and then dividing the -1/2(n^2 t^2) from both sides which left me with a big mess on the right, were the steps followed so far correct? Where would I go from here to solve for y?
Also, it has been suggested to me that this may require the use of the quadratic formula, is this correct?
Thanks.
Just move the -1/2(n^2 t^2 y) to the left side and factor out the y and from there it should be obvious...
Thanks for the reply. I have tried this:
https://imageshack.com/i/mu2vb0g
When I divide both sides by the coefficient I get a large formula on the right hand side which does not match the final result shown by the solver, I had also been told that the quadratic formula is required to solve this, could you please show me what I must do next?
Thanks.
You have a simple equation of the form ##y = A - By##, where
A = \frac{kt}{p}-\frac{k \sin(pt)}{p^2} \text{ and } B = \frac{n^2 t^2}{2}
Solving for y ought to be simple for you, without recourse to an on-line solver. Anyway, the solution given to you by the on-line solver is wrong. Are you sure you submitted the right equation?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
