Stopping a car before collision
  • Thread starter Thread starter hav0c
    Car Collision
To stop a car before colliding with a wall, the driver can either apply brakes, turn, or apply brakes while turning. The distance needed to stop when braking is calculated as (v²)/(2μg), while turning requires a radius of (v²)/(μg). The discussion highlights that applying brakes while turning results in a weaker force component directed away from the wall, reducing the effectiveness of stopping. The analysis suggests that the optimal angle for force application significantly impacts the stopping distance. Ultimately, the most effective method for avoiding a collision depends on the specific circumstances of the situation.
hav0c
A person driving a car suddenly sees a wall .At that instant velocity of the car is v. Coefficient of static and kinetic friction is μ. The mass of the car is M. To avoid the driver should ...(acc. due to gravity=g)
a)apply breaks
b)turn (the car shouldn't slip while turning)
c)apply breaks while turning (the car won't topple)
v=rω
f=ma
v=d(s)/d(t)
... other equations of motion
(ignore actual scenario of pumping the brakes)
In case the driver applies the brakes the distance traveled is simply (v2)/(2μg).
In case the driver turns the radius of the turn will be (v2)/(μg))
How will i work out the case of applying breaks and turning ?
Keeping maximum Force magnitude applied at some (fixed) angle from -v ...
you know the result for 0° is half the result for 90°.
Suppose you try it at 45° (then a∙r=-v∙v makes r become a function of remaining KE ... too bad).
The Force component pointing away from the wall is 71%, weaker than the simple braking case (100%),
so the Work done by that component while traveling to the wall must be less, at any other angle.
This means that the forward component of velocity is changed less, if F applied at any non-180 angle.
