Why do we see diffraction effects in radio waves but not in visible light?
Diffraction effects are more noticeable in radio waves than in visible light due to the longer wavelengths of radio waves, which allow for easier measurement of standing wave patterns. When light reflects off a mirror perpendicularly, the expected interference oscillations between constructive and destructive interference are not visible because the wavelength of visible light is much shorter, making such effects difficult to observe without specialized equipment. The phenomenon of colored reflections in thin oil films is an example of interference, as the oil film's thickness is comparable to the wavelength of light, allowing for observable effects. The discussion highlights the challenges in observing interference in visible light due to its short wavelength compared to radio waves. Understanding these differences is crucial for studying wave behaviors across different frequencies.
aaaa202
When you shine light on a mirror perpendicularly. Does the reflected beam then not interfere with the incoming one? With my intuition it would, and the interference would oscillate between destructive and constructive interference. But then why don't I see that when I do the experiment?
Science news on Phys.org
What is the time-scale of such oscillations? Do you have apparatus that can reveal changes on such a time-scale?
Or if you're thinking of spatial separation between maxima and minima, what sort of distances would be involved?
If you point a beam of radio waves at a reflecting metal plate you do get a standing wave pattern that you can measure easily. Because the wavelength of visible light is so short, you have to go to some trouble to observe obvious diffraction effects.
The coloured reflections from thin oil films on water puddles are due to interference. They form because the oil film is only around i wavelength thick and light is reflected both from air/oil and oil/water interfaces. (Google Thin Film Interference for some nice diagrams).
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
