Orbital theory - Molecular vs Hybrid orbitals
The discussion centers on the concepts of molecular orbital (MO) theory and hybridization in chemistry. It clarifies that when combining atomic orbitals from two or more atoms, they can form hybrid orbitals, which are involved in sigma bonding, or molecular orbitals, which allow for electron delocalization and can form pi bonds. Specifically, in the case of 1,3-butadiene, the four molecular p-orbitals and six hybridized sp2 orbitals illustrate this relationship. The conversation emphasizes that sp, sp2, and sp3 orbitals are considered atomic orbitals, even though they are hybridized. The distinction is made that hybrid orbitals are formed from atomic orbitals on the same atom, while molecular orbitals arise from the combination of atomic orbitals from different atoms. The discussion also suggests that a deeper understanding of these concepts can be gained through quantum chemistry literature, recommending McQuarrie's book on the subject.
christian0710
Hi I have a question regarding Molecular orbital theory:
Is it correctly understood that if we combine 2 or more atoms the atomic orbitals can become 2 things: They can either become Hybrid orbitals which are the orbitals that form sigma bonds between atoms, or they can become Molecular orbitals which are orbitals allowing the electrons to float freely around in the molecule in conjugated molecules and they always form pi bonds?
An example would be 1,3-butadiene: it has 4 molecular p-orbitals and 2*3= 6 hybridized sp2 orbitals? So the p-orbitals maintain their shape (like the atomic p-orbitals) but now we call them molecular orbitals.
Chemistry news on Phys.org
Not exactly. The molecular orbital theory you are talking about is better known as LCAO-MO: Linear Combination of Atomic Orbitals - Molecular Orbital. It is based on the idea that an MO can be approximated as the LC of AOs located on different atoms, but it says nothing about what those AOs should be. Most often, taking hydrogen-like AOs gives a good enough approximation to the MOs.
However, there are cases, and carbon is a good example, where these hydrogen-like AOs give predictions (such as bond angles) which make no sense. A good solution to this problem is hybridization: take the hydrogen-like orbitals, make linear combination of them into hybrid AOs, and use those in LCAO-MO theory.
The sp2 orbitals are AOs, which combine into MOs to form the σ bonds. The un-hybridized (left over) p AOs combine into MOs to form π bonds.
Hi and thank you for the reply:
So in the below example you mention that sp2 orbitals ARE atomic orbitals (how can sp,sp2,sp3 be atomic orbitals- I thought they were only hybrid orbitals?) which form to combine Molecular orbitals. I'm not sure I'm following what you wrote aboute the LCAO-MO theory. So is it a incorrectly understood that when atomic orbitals combine they form hybrid orbitals (which form sigma bonds), and the left over orbitals (which are not hybridized) Can or cannot overlap to form sigma bonds?
Can you recommend a book i can read to understand it more clearly? I'm taking organic chemistry, and I wan't to understand how Molecular Orbital theory can descibe or account for all the chemical bonds and chemical interactions taking place in chemistry.
Atomic orbitals correspond to possible states for electrons in an atom. The hybirdized sp, sp2 and sp3 orbitals are still orbitals calculated for one atom, and therefore are atomic orbitals.
I mentionned "hydrogen-like" orbitals because the s, p and d orbitals that you are familiar with are adapted from the solution you get for the hydrogen atom (only one electron). When considering atoms with more than one electron, exact solutions are not possible, and an approximate description for orbitals is used.
When atomic orbitals are combined on one atom, the result is called hybrid orbtials (which are still atomic orbitals). When atomic orbitals are combined on different atoms, the result is a molecular orbital. When molecular orbitals are occupied, this can lead to the formation of a bond (ut not necessarily, some molecular orbitals are anti-bonding).
In organic chemistry, you are mainly concerned with the hybridization of C (although N hybridization can also explain the bonding in some molecules). In most cases, the hybrid orbitals will form sigma bonds and the left-over p orbitals (for sp and sp2) will make pi bonds.
You have to look at books on quantum chemistry. A good choice is the one by McQuarrie:http://books.google.se/books/about/Quantum_Chemistry.html?id=zzxLTIljQB4C&redir_esc=y
One should also mention that hybrid orbitals are a concept from valence bond theory rather than molecular orbital theory.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
