What Are the Top Beginner Resources for Learning Loop Quantum Gravity Online?
craigi
What are the best online introductory resources for Loop Quantum Gravity?
I've never felt more out of my depth than when listening to Rovelli speak on the subject.
LQG is a subject that is built off of general relativity and quantum field theory, so you should understand that a good introduction would still assume 2 years of graduate coursework...
Regardless, I found the following to be a pretty good intro: http://arxiv.org/abs/1102.3660
I also read Rovelli's book on the subject, which is a bit out of date compared to his Zakopane lectures but it goes into more detail with the derivations.
There is also this review: http://arxiv.org/abs/1303.4636
There was a thread about LQG introductory resources started about one year ago
https://www.physicsforums.com/showthread.php?t=676720
This came up in that thread. It is recent, has 85 pages and 20 figures, is online
http://arxiv.org/abs/1402.3586
Sundance Bilson-Thompson, Deepak Vaid
School of Chemistry and Physics, University of Adelaide, Adelaide SA, Australia
Department of Physics, National Institute of Technology Karnataka (NITK), Surathkal, Karnataka, India
Abstract: We present a pedagogical introduction to the notions underlying the connec- tion formulation of General Relativity - Loop Quantum Gravity (LQG) - with an emphasis on the physical aspects of the framework. We begin by reviewing General Relativity and Quantum Field Theory, to emphasise the similarities between them which establish a foun- dation upon which to build a theory of quantum gravity. We then explain, in a concise and clear manner, the steps leading from the Einstein-Hilbert action for gravity to the construction of the quantum states of geometry, known as spin-networks, which provide the basis for the kinematical Hilbert space of quantum general relativity. Along the way we introduce the various associated concepts of tetrads, spin-connection and holonomies which are a pre-requisite for understanding the LQG formalism. Having provided a minimal introduction to the LQG framework, we discuss its applications to the problems of black hole entropy and of quantum cosmology. A list of the most common criticisms of LQG is presented, which are then tackled one by one in order to convince the reader of the physical viability of the theory.
An extensive set of appendices provide accessible introductions to several key notions such as the Peter-Weyl theorem, duality of differential forms and Regge calculus, among others. The presentation is aimed at graduate students and researchers who have some familiarity with the tools of quantum mechanics and field theory and/or General Relativity, but are intimidated by the seeming technical prowess required to browse through the existing LQG literature. Our hope is to make the formalism appear a little less bewildering to the un-initiated and to help lower the barrier for entry into the field.
sundance.bilson-thompson@adelaide.edu.au
deepak@nitk.edu.in
There are other introductory resources. I can't list them, but you could try this one and see if it is right for you. If not, say how this one does not fit your needs and ask again. We can try to suggest something else that is closer to what you want. So maybe by successive approximation we will get a good fit
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
