SkyActiv 2 engine that is cleaner than electric
  • Thread starter Thread starter Greg Bernhardt
    Electric Engine
Mazda's SkyActiv-G Generation 2 engine aims to improve fuel economy and reduce emissions through the use of homogeneous charge compression ignition (HCCI) and a higher compression ratio of 18:1. This technology enhances thermal efficiency significantly compared to the previous generation. The engine is designed to meet stringent emission standards without relying on electronic equipment. Some participants in the discussion referenced alternative engine technologies, such as the Hot Vapor Cycle Engine, suggesting that electric vehicles may not be as clean as perceived. Mazda's advancements indicate a potential shift in the automotive industry's approach to cleaner gasoline engines.
Cleaner than electric? Mazda talks up gasoline engine fuel economy ambitions for SkyActiv 2
At Mazda, the engine of the future is called the SkyActiv-G Generation 2, a follow-up to Mazda's SkyActiv-G Generation 1. For SkyActiv-G Generation 2, Mazda will adopt homogeneous charge compression ignition (HCCI) and an even higher compression ratio of 18:1 over SkyActiv-G Generation 1 high compression ratio of 14:1. Mazda said on its site that increasing the compression ratio considerably improves thermal efficiency. According to Autocar, it is likely SkyActiv-G Generation 2 technology could arrive in production before the decade is out..
For SkyActiv-G Generation 2, Mazda will adopt homogeneous charge compression ignition (HCCI) and the higher compression ratio of 18:1. Autocar said The HCCI system works in a way similar to a diesel engine, using piston compression rather than a spark plug to ignite the mixture in the chamber.
http://phys.org/news/2014-03-cleaner-electric-mazda-gasoline-fuel.html
Sounds like what I read in 1983.
What engine is smother than an electric motor, meets all emission standards without electronic equipment, produces 2 horsepower per cubic inch of engine, can deliver 60 miles per gallon and weighs only 170 pounds?
Hot Vapor Cycle Engine - HVCE
The Adiabatic Engine developed by Henry “Smokey” Yunick in the late 1970s. Summary - He super heated gasoline and air mixture and introduced it into the combustion chamber WITHOUT DETONATION.
Perhaps someone finally realized electric isn't all that clean? :wink:
he said wryly with a nod and :approve: a wink
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
