Boundary condition between conductor and free-space
In the discussion about boundary conditions between a conductor and free space, it is highlighted that an imperfect conductor generates an electric field inside the wire aligned with the current flow. The confusion arises regarding the continuity of the tangential electric field at the boundary, especially when there seems to be no external electric field. It is suggested that there is indeed an external electric field, which is perpendicular to the wire, while the electric field inside the conductor remains parallel to the current density. The conversation emphasizes that outside the conductor, in a dielectric medium, the field is oriented differently, but an equipotential line follows the conductor's surface. Overall, the relationship between electric fields inside and outside the conductor is complex and depends on the conductor's properties and the surrounding medium.
yykcw
For an imperfect conductor, when there is current, an electric field is set up inside the wire along the direction of the current flow, and is parallel to the wire.
If this is true, then what I don't understand is
boundary condition tells me the tangential E-field is always continuous, if there is no E-field outside the wire, how come there will be E-field inside the wire?
There must be some electric charge on the wire, and some electric field outside the wire.
But isn't that those E-field outside is perpendicular to the wire?
I don't understand why tangential E-field will exist outside.
I think this is your problem. Imo, there will be an E field outside the wire which, for a straight wire, between two large flat plates (the easiest example I can think of), will bt ΔV/x where ∇V is the voltage drop (imperfect wire) and x is the length.
The current density-J- in conductor includes only “free current density” since the polarization current is negligible then E=ρJ .That means in a conductor the electric field [intensity] E is parallel with current density –directed along the conductor.
Outside-in a dielectric as air or insulation-it is no free current then the field is oriented perpendicular to the conductor tangent. However, no tangent field exists- in my opinion-only an equipotential line follows the conductor outside surface.:shy:
Perhaps consider an extreme case...very high resistance wire (say 1Meg ohm) laying straight with high voltage source driving the ends against each other (say 1Meg V). You may agree that there will be a tangential E-field in the direction of the wire right?
Now just scale things down to uohms and volts.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
