Geometric efficiency of a detector
The discussion revolves around calculating the geometric efficiency of a gamma detector setup involving a 4MBq source emitting 5 KeV photons. Participants express uncertainty about whether to treat the source as a point source due to the lack of information on its radius. The hint suggests that if the detector window completely surrounds the source, it would achieve 100% geometric efficiency. The conversation also touches on the need to consider isotropic emission of photons from the source. Overall, the participants seek clarity on how to apply the given parameters to solve the problem effectively.
Soilwork
I'm not to sure how to do this question.
Q. A 4MBq gamma source emitting 5 KeV photons is held at a distance of 5 cm from the end window of a detector. The diameter of the detector window is 3.5 cm, and the quantum detection efficiency of the detector is 15%.
i)What is the geometric efficiency of the setup?
ii) What fraction of the source activity is recorded by the detector?
Well I dont' particularly have a clue about the first part. I know that if it is point source you can neglect the term
y(gamma)= (radius of source)^2/(distance to detector)^2
But the question doesn't say if it is a point source or not.
If it isn't then I don't really know because you don't have the radius of the source.
Obviously I will have to use all the information given and I just can't see how to use it all.
I'm sorry I'm not too good at this stuff, but I'm trying to study for my exams in a couple of weeks and would appreciate any help :)
Hint: If the detector window COMPLETELY surrounds the source, you will have 100% geometric efficiency.
It is asking for how much of the photons actually made it into the detector at that distance, with that opening area.
Zz.
To find the number of photons make it to the detector you would need to know the radius of the source which you don't know.
so would it be reasonable to assume that it's a point source then?
One can only assume, after reading the nature of the problem, that the source emits those photons isotropically.
Zz
Thank you for that :)
I think I can do the second part using the fact that Ro=kR
where R is the activity of the source and Ro is the detected activity.
k = (number of particles produced)*G*E
where G and E are the geometric and detection efficiencies.
haha ok maybe I can't do the second part :(
I assume I'd have to use the quantum detection efficiency along with the initial activity and the energy of the gamma rays.
So damn frustrating because the lecturer's notes barely cover this and we don't actually have a book.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
