Find the path equation for the vector field V = ky*i + kx*j
  • Thread starter Thread starter dk_ch
    Path Vector
8 replies · 2K views
dk_ch
1. The problem
if {\vec{V}=ky\hat{i}+kx\hat{j} find the equation of the path
dk_ch said:
1. The problem
if ##\vec{V}=ky\hat{i}+kx\hat{j}## find the equation of the path
You need to show your attempt, or at least describe your thinking.
What do "x" and "y" represent here? If they are two independent variables this is surface not a path.
are you dealing with parametric equations?
I wrote vel components separately as dx/dt and dy/dt . then the relations were integrated to have two equations relating x,y and t. Finally i eliminated t to get the equation. was i right?
i got eq (1) x = kyt +c1 and eq (2) y = kxt+c2
and final eq was (x-c1)/(y-c2)=y/x
i got eq (1) x = yt +c1 and eq (2) y = xt+c2
Well that solution is not correct is it? Just differentiate it to check with the original equation (making sure to use the product rule) and you will see that.
y and x are functions of t, so you cannot integrate y with respect to t and get yt.
I would start by getting out of vectors and represent the equation as two simultaneous scalar differential equations. Then you can eliminate one dependent variable to obtain a second order ODE.
There may be neater ways.
You will also need to known the position at t=0.
thanks , I had doubt .
May I do it as follows .
dx/dt =ky and dy/dt=kx hence dx/dy=y/x or xdx=ydy .now by integrating we can get the result as y^2=x^2+ constant. .
please confirm.
please confirm.
Yes, much better than my way.
