Threaded connection's initial contact modelling using ANSYS workbench
The discussion revolves around modeling a threaded connection in ANSYS Workbench, focusing on initial contact and convergence issues. The user has set an initial overlap and defined frictional contact but is questioning the accuracy of this approach. A suggestion was made to start with an initial gap between the threads and gradually introduce interference to better represent the physical behavior of threaded connections. The user seeks clarification on whether it's feasible to model initial contact without interference and how to implement gradual interference over time steps. Effective modeling techniques are crucial for accurately simulating stress in threaded connections.
Pakhoz
Hi everyone! I am doing a simulation of threaded connection in ANSYS workbench and have some problem.
In this 2D model, the initial make-up is modeled by setting an "initial overlap" (shown in figure 1).
This is how I did:
- The initial contact between pin and box as "frictional" with coefficient of friction 0.03. Formulation used is Augmented Lagrange. With interface treatment: offset (ramped) 0.08 inch.
The other constraints/ loadings:
- The upper part (box) is restricted by "frictionless support" on its edge on the right to ensure it can't move along x direction
- The lower part (pin) is restricted by "frictionless support" on its bottom edge to ensure it moves only along x direction.
- A pressure load is added on the left edge of the pin.
My question:
Is the way I address the initial contact right ? How can I get the stress induced by this initial contact ? And why this model is always not convergent ? Can anybody give me some advice?
Thank you for your suggestions.
- Pakho Cheng
I don't think this is a good representation of a threaded connection; in reality the model should have an initial gap between the threads, and then you should move one of the parts axially to create a connection on one side of the thread faces.
Your current model basically assumes an oversized thread being forced into an underiszed one, but the initial geometry interference you have cannot be solved because you need to start with no interference and then slowly introduce the interference over some time steps.
Thank you for your reply.
Instead of making an initial gap between the threads, can I develop these two surface bodies initially contact with each other with no interference, and then give the pin a y-direction displacement equal to the "initial gap" to model the interference?
Because I think when the two parts are at make-up situation, both the flanks of each thread will have contact. If you move one of the parts axially to make them contact, the contact region is probably on only one flank of the thread?
If what I say makes sense, how can I introduce the interference slowly over some time steps as you say?
Thanks.
P.C
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
