Why do we need the vertical distance that a bouncing ball traveled?
Tizyo
1. Homework Statement
1.Main question: Why would anyone need to know the total VERTICAL distance traveled by a bouncing ball?
2.Other question: Does anyone have a link to an explanation (or could explain themselves) on how to calculate the total HORIZONTAL distance traveled by a bouncing ball?
3. The Attempt at a Solution
For the second question, I have filmed and analysed (plotted the points) of a few trajectories, so I have the values, I just need to explain why i got those values and I don't know how..
Depends on the context.
For instance, someone could be paying you to find out.
(Have you tried to find it? The reason usually becomes clear when you do.)
It is the horizontal speed multiplied by the time to come to rest ... or some other approach depending on your data.
Please note: apart from the question, no problem statement has been attached.
You got those values because those are the ones you filmed <puzzled>.
I think you need to provide a more complete description of the problem you are facing, but it sounds like you are over-thinking things.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
