Simple harmonic motion and circular motion
Simple harmonic motion (SHM) is closely related to uniform circular motion, as the latter can be viewed as two-dimensional SHM. When an object moves in a circle, its projection onto a Cartesian coordinate system reveals that the x and y coordinates follow SHM equations, specifically x=R*cos(wt) and y=R*sin(wt). This demonstrates that uniform circular motion consists of two SHMs with the same frequency but a phase difference of π/2, and the components are perpendicular to each other. The typical representation of SHM can be interpreted as the x component of circular motion. Understanding this relationship enhances the comprehension of both motion types.
gunparashar
why simple harmonic motion is projected as or compared with uniform circular motion ?
Because uniform circular motion is essentially "two dimensional simple harmonic motion."
Consider the shadow of an object moving in a circle when the light is shined "edge on". (This essentially "collapses" or "ignores" one of the dimensions of the motion)
Well if one considers a cartesian coordinate system with origin at the center of the circle of the uniform circular motion, then can prove fairly easily that the x and y coordinates (of the particle that does circular motion), are doing simple harmonic motion. That is it will be x=R*cos(wt) and y=R*sin(wt) where w the angular velocity, R the radius of the circle.
So you can view uniform circular motion as composition of two simple harmonic motions of the same frequency, with phase differnce pi/2, and (thats important) of direction perpendicular to each other.
The usual form the solution is given in, that is in terms of a shifted cosine, can be interpreted as the x component of a body in uniform circular motion.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
