Speedometer worm gear ratio changes
Changing rear end gear ratios or tire sizes requires different speedometer gears to maintain accuracy, as the driven gear can be replaced without altering the driving worm gear or center distances. The worm gear, typically with 7 or 8 teeth, remains fixed, while the driven gear's outside diameter varies, allowing for tooth counts between 15 and 23. The center-to-center distance remains constant due to an eccentric hole in the transmission, enabling various gear sizes to mesh properly. Aftermarket options provide numerous combinations for customization. Newer vehicles have transitioned to electronic speedometer systems, utilizing sensors instead of traditional cables.
jb5point0
When changing rear end gear ratios, or tire sizes on a vehicle, you can buy different speedometer gears with tooth counts to restore speedometer accuracy. The worm(driver) is inside the transmission and is not changed. It is a 7 or 8 tooth in my application. The speedometer gear(driven) is replaceable and comes in 15 to 23 tooth counts.
Just wondering which engineering design principles are allowing tooth changes in the driven gear without any changes in the driving worm gear or in the center to center distances of the gear set.
Some design parameter is taking a beating i suspect.
The center to center distance stays the same. It is the outside diameter of the driven gear that changes. Even so there is a limit to how far one can go without having to change the drive gear. The teeth can still be cut to fit the worm gear.
I have always presumed that it was the difference in outside diameter of the driven gears that made it all work.
I remember that the old Muncie four speeds had a about six different numbers of teeth on the driven gear that it could accommodate without having to change the drive gear.
We can thank the aftermarket for the nine zillion combinations that are available.
The newer cars have gone electronic with a magnet located on a gear and no cable. Some new VW's even use one of the antilock brake sensors to send the signal.
Edit: OK those little alarm bells in my head just rang. The center to center distance stays the same because the hole in the side of the transmission is eccentric to the drive gear. Turning the driven gear housing to the right makes the gears mesh. This allows several size gears and numbers of teeth to be used.:redface:
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
