Resolution (visual acuity) and screen discreteness
  • Thread starter Thread starter fog37
    Resolution Screen
Resolution in optical systems is defined by the ability to distinguish closely positioned objects, with higher resolution being preferable. The diameter of the aperture stop typically determines resolution in systems with multiple lenses, rather than the lens diameter itself. When imaging screens are discrete, like the human retina, the size of photoreceptors should ideally be smaller than the Airy disks to avoid aliasing and artifacts. If the pixel size is too large compared to the Airy disk, it can lead to undersampling issues that degrade image quality. Overall, resolution is influenced by lens diameter, light wavelength, and the number of receptors on the imaging screen.
fog37
Hello Forum,
Resolution is an angular distance (measured in fractions of an 1 degree angle). The lower the resolution the better. It represents the ability to distinguish two objects that are very closer to each other.
For an optical system, the resolution increases when the diameter D of the lens increases (or if the wavelength of the used light decreases).
1) If the system has multiple lenses, will the aperture pupil determine the resolution or the size of the aperture stop?
Because of the unavoidable diffraction, two object points will be imaged by a circular lens as Airy disks. If the two discs are too large they will overlap and look like a single blobby image: we will not be able to distinguish the two objects separately.
The two point images (Airy discs) form on the imaging screen that is often assumed to be continuous. What if the imaging screen is (like the human retina) discrete an formed by a finite number of photoreceptors with a certain size and shape?
Does the size of each receptor need to be smaller, larger or equal to the diameter of the Airy disks?
Thanks,
Fog37
First, the higher the resolution the better, as higher resolution means you can distinguish objects closer to each other than a lower resolution.
If the system has multiple lenses, it is usually the diameter of the aperture stop that determines the resolution. For example, my telescope has an aperture stop that is 8 inches in diameter, while the mirror is about 9 inches in diameter. The resolution is the same as an 8 inch mirror that doesn't have an aperture stop. (The reason for the difference is that having the mirror larger than the aperture stop helps with vignetting)
If you are worried about resolution, your detector should have a pixel size approximately 2-3 times smaller than your airy disk. See here: http://starizona.com/acb/ccd/advtheorynyq.aspx
fog37 said:
<snip>
Discrete (sampled) imaging systems can be more difficult to analyze because they are not linear shift-invariant systems: small shifts in object position don't result in small shifts of the image. Often, the pixel size is designed to be much smaller than the Airy disc, and as Drakkith notes, in that limit 'normal' rules apply. The opposite limit (pixel size much larger than the Airy disc) is not much relevant.
In between, a variety of imaging artifacts can occur, most notably 'aliasing' which is the introduction of spurious high-frequency components to the image caused by the mismatch between sample frequency and image frequency, similar to Moire' patterns. The best (IMO) book to understand this is Vollmerhausen and Driggers' "Analysis of Sampled Imaging Systems" (SPIE press)
Note that the retina is not anything like a simple pixelated array- there are multiple processing layers located in the retina that operate on the signal prior to the optic nerve.
So, in essence, for the simple case of a single lens and a viewing screen with a finite amounts of receptors on it, the resolution is primarily determined by the diameter D of the lens and wavelength of light and later by the number of receptors on the screen.
If there are too few receptors we run into the problem of undersampling that leads to artifacts which compromise the overall resolution.
fog37
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
