Solving Impulse & Momentum Problems: Troubleshooting an Error
  • Thread starter Thread starter verd
    Impulse Momentum
The discussion revolves around troubleshooting an error in calculating the final velocity of a hockey puck after applying a force. The user initially believes they followed the correct procedure but struggles with part c of the problem, where a force is applied in the opposite direction. After some back and forth, they realize that the mistake lies in not taking the absolute value for the magnitude of the final velocity, which should be reported as 0.68 m/s instead of -0.68 m/s. The conversation highlights the importance of understanding impulse and momentum concepts, as well as the potential quirks of the 'Mastering Physics' program used for assignments. Ultimately, the user acknowledges their error and expresses gratitude for the assistance.
verd
Okay, So... I'm having trouble understanding what I did wrong here. I can't seem to understand how I got this problem wrong.
Here's the problem statement:
A 0.160-kg hockey puck is moving on an icy, frictionless, horizontal surface. At t=0 the puck is moving to the right at 2.98 m/s.
a.) Calculate the magnitude of the velocity of the puck after a force of 24.9 N directed to the right has been applied for 4.80×10−2 s.
b.) What is the direction of the velocity of the puck after a force of 24.9 N directed to the right has been applied for 4.80×10−2 s.
c.) If instead, a force of 12.2 N directed to the left is applied from t=0 to t= 4.80×10−2 s, what is the magnitude of the final velocity of the puck?
d.) What is the direction of the final velocity of the puck in this case?
So I've got everything right-- except for part c. ...I would imagine that I'd do it the exact same way I did part a. This is what I did for part c:
J_{x} = impulse
J_{x} = p_{2x} - p_{1x}
J_{x} = F_{x}(t_{2}-t_{2}) = -12.2(.048) = -.5856
p_{2x} = J_{x} + p_{1x} = -.5856 + (.16)(2.98) = -.1088
v_{2x} = \displaystyle{\frac{p_{2x}}{m}} = \displaystyle{\frac{-.1088}{.16}} = -.68m/s
Why is this wrong? What did I do wrong?
Thanks!
Initial momentum: mv = 0.16*2.98 kgm/s
Impulse: Ft = -12.2*0.048 kgm/s
The impulse is the change in momentum.
...Okay, so Ft stands for... impulse?
If so, I indicated that I already found the value for that one, which would be approximatley -.5856
I still don't know what I did wrong.
Nevermind, I'm getting the same answer you did.
Haha, weird. ...We use the program, 'Mastering Physics' at the University I attend... And the damn thing has been kind of quirky already. Perhaps it could be messing things up, because I keep doing the problem, different ways, and I still get the same answer.
Who knows.
I keep rereading it, thinking I missed out on something. This is EXACTLY what I was given:
And this is how I came about my solution... That apppears to be incorrect:
J_{x} = impulse
Thanks!
Can anyone else seem to figure how this is wrong?... There has to be something...
Hah. I got it.
what is the magnitude of the final velocity of the puck? As we know, magnitudes are absolute values. So our answer would be 0.68 instead of -0.68.
Although, usually the program will tell you that you got your negatives and positives mixed up. Strange it didn't do it this time.
Thanks, by the way!
Yeah I justn oticed that and was abuot to say. I used masteringphysics for kinematics an E&M, i hated it.
