Cutting Strong Materials: Silicon Carbide & Aluminium Oxide Techniques
  • Thread starter Thread starter sid_galt
    Cutting Silicon
Silicon carbide and aluminum oxide, known for their strength and high melting points, are primarily shaped and cut using diamond-tipped tools or grinding wheels. These cutting tools often consist of hard materials embedded in a matrix, allowing for effective shaping while managing brittleness. Sintering is a common process for forming these materials, where powdered particles are fused together, but grinding wheels are typically formed rather than cut. For cutting, harder substances like diamond-coated surfaces on metal substrates are used, often with water cooling to manage heat. Plasma etching is another method, though it tends to be more energy-intensive and costly.
sid_galt
How are materials like Silicon Carbide or Aluminium oxide which are strong and have high melting points shaped and cut? Just wondering.
Is a diamond tipped cutter used or something?
As I understand it, they are sintered. The cutting surfaces aren't made from solid silicon carbide/tungsten carbide/whatever. They're lots of little particles, essentially held in by cement.
... think so too, don't think there is much else you can use except sintering, essentially a diffusion process.
Well, you can actually cut something with material of the same hardness, but it wears the tools out quickly.
That said, if you start looking at 'exotic' cutting materials like diamond, cubic boron nitride, and so on, what often happens is that the cutting material is in a matrix of something else. This is useful for shaping, and also because the harder cutting materials tend to be brittle (and friability is a desirable characteristic at times.)
Grinding wheels (which is where AlO and SiC are popular) are typically formed, not cut.
Most ceramic and many metal products are formed using 'near net shape' processes. The green ceramic is sintered to the final product.
To cut, a substance, one simply needs a harder substance, and in most cases, this means a diamond coated surface on a metal substrate, e.g. copper disk, with water cooling.
On could also use a plasma etch, but that is often more energy intensive and therefore more expensive.
Sintering is a process for forming objects from powder, usually used for ceramics. http://en.wikipedia.org/wiki/Sintering
Grinding wheels are usually not sintered:
http://www.mmsonline.com/articles/120003.html
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
