What was the speed of the bullet at impact?
The discussion revolves around challenging physics problems assigned by a teacher to a high school intro physics class. Students are seeking guidance on how to approach calculations involving gravitational field strength, bullet impact speed, and other physics concepts. Key equations mentioned include the gravitational force formula and the relativistic velocity addition formula. Participants express confusion over the adequacy of given information and the correct application of formulas. The thread highlights a collaborative effort to gain a better understanding of these complex topics.
stitch12
these questions are challange questions from our teacher (MIT grad) who gave us these knowing that they were a bit out of reach for us as we are a beginning intro physics class(HS). we haven't but scratched the surface on these topics. so we're trying to find/acquire at least a basic, rough understanding so we can say "ah ha. you've not been completely successful in stumping us." because he gets a laugh when we come in and don't have a clue. and he wins. so our whole class is desperately looking for something to show for these problems.
here are some physics questions that i am puzzled on and lost. help! if you are able to solve them please show how, or at least what formulas/equations you used to get there. thanks! (even if you have a clue take a shot!anything could help).
3.gold has a density of 1.74x10^3 kg/m^3. calculate the gravitational field strength 10m from a 1m cube of gold.
4.the 3.56g bullet from a 22-250 rifle is fired vertically into a 1.174kg block of wood. the bullet sticks to the block, which rises 0.595m. what was the speed of the bullet at impact?
6.if an astronaut dropped a small rock on the surface of mars, how far would it fall in 1.00 seconds? the mass of Mars is 0.107 that of Earth and the radius of Mars is 0.53 that of earth.
8.calculate the mass of Jupiter from the information that its moon Io orbits at an average distance of 4.22x10^5km from jupiter's center and has an orbital period of 42.5 hours.
10.a spacecraft traveling at 0.8c away from the Earth launches a probe that is traveling 0.95c from the spacecraft 's frame of reference. what is the speed of the probe from the point of view of the earth?
11.what is the acceleration due to gravity 1000km above the surface of the earth?
for #11 i used the formula : acceleration = change in speed/ time interval and got what seems to be a logical answer...(this was the right equation ..right?)
for #10 i multiplied 0.8 times 3x10^3 (the constant for speed of light) and 0.95 times the same : 3x10^3. was this a right move? what should i do with these values now? it doesn't give me distance or time values. so what eqaution can i plug these values into if they are all i have?
4 seems like it didn't give me enough values.
You should know that FG= GmM/r2[/sup] so the "field strength" is GM/r2.
You are given r, you are given the density and volume and so can calculate M, you can look up G.
You know the total mass of bullet and block is M= 0.00356+ 1.174 kg so you can calculate the momentum after impact. That must be the momentum of the bullet alone before impact.
You know that an object will fall 9.8/2= 4.9 m in one second on earth, that gravitational force (and so acceleration) is proportional to mass and inversely proportional to radius.
Do you know the relationship between the acceleration toward the center of a circle and its period? Once you know the acceleration, you an use a= GM/r2 again.
The relativistic "sum of velocities" formula is (u+v)/(1+ uv/c2)
One more time: GM/r2. Of course, r is the distance from the center of the earth, not surface. You know that GM/r2= 9.81 for r= radius of earth.
Really? I would be interested to know WHAT values you used for "change in speed" and "time interval". They weren't given in the problem.
Well, yes, if you want the speeds in m/s. Were you asked that? What you need is the formula for combining speeds: if the speeds are very LOW, the "add": v1+ v2. These are NOT very low!
What other values would you like?
hey everyone. thanks i needed those equation directions.
