Materials safe for food machines
When designing machines for food handling, it's crucial to avoid materials like PVC due to safety concerns and potential contamination. Food-grade plastics are necessary for any product intended for market, and the choice of materials should align with their intended use and safety standards. Pure polymers are generally non-toxic, but additives used in manufacturing can pose risks. For storage, polyethylene (PE) and polyethylene terephthalate (PETE) are recommended, while cooking applications should utilize ceramics or stainless steel for their sanitization properties. Ensuring that all materials in contact with food are of high quality is essential to prevent contamination.
iggybaseball
I've recently drawn up several machines that handle food. However I wanted to know if there are any materials that I should stay away from, for handling food. To clarify, I would like to go to a harware store to pick up supplies, but is it ok to run liquids or store food in pvc for example. What about when it comes to liquids. If anyone would like to suggest materials that I could use safely or that I should avoid, I would appreciate it greatly. Thanks.
Are you asking just about polymers?
I didn't watch it, but http://www.bluevinyl.org/ is a supposed documentary about the use of PVC and other vinyls for food use. Apologies if it's useless, I couldn't be bothered to download it.
Anyway, there are concerns about the use of PVC in food applications, and in any case if your intentions are to market a product, you'll probably have to use certified food-grade plastics. Obviously, your material selection depends as much on the actual application as any safety issues, - it's pointless to use a safe plastic if it doesn't fulfil other criteria.
It should be remembered that all pure polymers themselves are non-toxic, but many additives (colourings, hardeners, stabilisers etc) added during the various manufacturing processes are.
The choice of materials depends on the conditions.
Storage containers can be made of polyethylene (PE) or polyethylene terephthalate (PETE), e.g. beverage containers.
Cooking would require ceramics like Pyrex or certain whitewares, or perhaps stainless steel. In the dairy industry and food processing industry, stainless steels are used because they can be sanitized after use.
One thing you have to sure of, is contamination, if a slither of plastic finds
its way into a food product it is virtually un detectable, nearly all mass
produced food passes through a metal detector, so any part of the machine
in contact with food should ideally be high grade s/steel.
We have audits to account for every plastic, glass item in factory, even biro
pen tops are not allowed.
Cool site Brews.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
