Calculating Heat Loss/Gain in Copper & Liquid
  • Thread starter Thread starter Dark Angel
The discussion focuses on calculating heat loss and gain when a 10kg block of copper at 100°C is dropped into 2kg of liquid at 20°C. The copper cools by 80K, releasing 308,000 J of energy. The liquid absorbs this energy, warming up by 80K, which is expressed as 160y J, where 'y' is the specific heat capacity of the liquid. The heat gained by the liquid originates from the energy released by the copper. Ultimately, the specific heat capacity of the liquid is determined to be 1925 J/kgK.
Dark Angel
hey guys i wuz thinking if anyone could help me here.
A block of copper of mass 10kg is heated to 100 degree C. it is then dropped into 2kg of a liquid at a temp.of 2o degree C.
a) thruough how many kelvin did the copper cool?
b) how much nrg did d copper release as it cooled?
c) by how many kelvin did d liquid warm up/
d) let the specific capacity of d liquid in j/kg/K be 'y'. in terms of 'y', how much nrg must the liquid have gained as it warmed up?
e) where did dis heat nrg gained by th liquid come from?
f) bearing in mind ur ans. to (b),(d) and (e), work out a value for d specific heat capacity of d liquid.
You know, there's a link to the "HomeWork" side at the topof this page ...
but I will hint that, if you only have a *symbol* for the liquid's "c",
the final temperature will *depend on* that symbol.
Tell me why ...
a) The copper cooled from 100°C to 20°C, which is a decrease of 80°C or 80K.
b) The amount of energy released by the copper can be calculated using the specific heat capacity of copper (which is 385 J/kgK) and the change in temperature. So, Q = m x c x ΔT = 10kg x 385 J/kgK x 80K = 308,000 J.
c) The liquid warmed up from 20°C to 100°C, which is an increase of 80°C or 80K.
d) The amount of energy gained by the liquid can be calculated using the specific heat capacity of the liquid (which is y J/kgK) and the change in temperature. So, Q = m x c x ΔT = 2kg x y J/kgK x 80K = 160y J.
e) The heat energy gained by the liquid came from the heat energy released by the cooling copper.
f) By comparing the amount of energy released by the copper (308,000 J) and the amount of energy gained by the liquid (160y J), we can calculate the specific heat capacity of the liquid as y = 308,000 J / 160 J/kgK = 1925 J/kgK.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
