How do you physically interpret ft-lbs or torque?
  • Thread starter Thread starter david90
    Torque
Torque is a measure of rotational force, and it can be calculated using the force applied perpendicular to a moment arm, expressed in ft-lbf or N-m. To increase a scooter's speed from 15 mph to 20 mph, additional power is needed to overcome increased resistance, primarily wind drag. The motor's RPM and the gearing must be optimized to ensure the driving wheels can achieve the desired speed. A torque vs. RPM graph can help determine the power required at different speeds and whether the motor can reach its maximum RPM under load. For the scooter in question, adding two more electric motors with a smaller gear ratio may be necessary to achieve the target speed.
david90
how do you physically interpret ft-lbs or torque?
say I have a scooter that goes 15mph and I would like to add another motor to make it go 20 mph. What kind of calculation would I have to make to determine the required motor power?
Torque can be thought of as a rotational force, which can achieved by a 'linear' force applied perpendicular or normal to a moment arm - hence ft-lbf, or N-m. In the motor, the piston (through a rod) imposes a force on the crank shaft, and the crank shaft produces the torque.
I am not sure of your question about a motor enabling 15 mph vs 20 mph. Do you plan to replace the motor or add a second motor?
To go faster one needs more energy/power as the resistance (mostly wind resistance) increases with speed - so more energy/power is required.
Also, the motor needs to turn fast enough or the gearing must be arranged to permit the driving wheels to turn at the appropriate vehicular speed.
You would also want the RPM the torque is being measured at so you can figure power. And since you would be well suited with more information in this case, a chart/graph would be even better.
So one way to interpret it would be to have a graph of torque vs RPM, from that you can create a power vs RPM (and vice versa). Now if you know the RPM of the motor at the top speed you can make a determination if the engine is simply at its top RPM (at which point the power is a non-issue) or if the resistance is high enough to prevent it from reaching maximum RPM the amount of power needed to maintain that top speed.
If the engine is making more power at a different point on the graph, you may be able to shift the gearing up/down to allow the power curve to better suit your top speed goals. Or approximate the power needed to increase the speed - I thought I had a rudimentary understanding of aero drag but some posts lately make me question that so I'll leave that for someone else.
Electric or gasoline powered scooter by the way? And the additional or replacement motor is what?
it is electric and it is additonal to the other two stock electric motors. There is no way I can gear down or up the two stock motors fo sure so I guess to achieve high max speed is by adding two more motors with smaller gear ratio.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
