Finding a Vector Valued Function for a Curve: Counterwise/Clockwise
To find a vector-valued function for the curve defined by the equation 4x² + 9y² = 36, it can be rewritten as (2x)² + (3y)² = 6², indicating an ellipse. By substituting w = 2x and z = 3y, the equation transforms into a circle in the w-z plane, which can be parametrized using the standard circle equations x = a*cos(t) and y = a*sin(t). For counterclockwise tracing, the parameter t should increase positively. The final step involves converting back to the original variables x and y to complete the parametrization. This approach will yield the desired vector-valued function for both counterclockwise and clockwise directions.
brad sue
Hi,
I do not know how to do this exercise:
Find a vector valued function f that traces out the given curve in the indicated direction.
4x2+9y2=36. a- Counterwise b- clockwise
Thanks
Hi brad,
Here's an idea: First rewrite the equation (which is probably one of an ellipse) as (2x)² + (3y)² = 6². This strangely resembles the equation of a circle. In fact, if we perform the changes of variable w = 2x and z = 3y, then the equation (2x)² + (3y)² = 6² <==> w² + z² = 6² is that of a circle of radius 6 in the w-z plane. You know how to parametrize a circle, right? Then do so and then change back to the variables x & y to find the corresponding parametrisation in the x-y plane.
In case you don't remember the parametric equations of a circle are
x=a*cos(t)
y=a*sin(t)
Where a is the radius and as t increase in the positive direction the circle is traced out in a counter-clockwise direction...
With that and the information quasar987 gave you, you should be able to figure out what to do...
Good luck
x=a*cos(t)
y=a*sin(t)
Good luck
Thanks to you both
