Why include a 1/2 factor in the drag equation?
  • Thread starter Thread starter damosuz
    Drag
The inclusion of the 1/2 factor in the drag equation F_{R} = \frac{1}{2}\rho C_{d}A v^{2} is essential because it aligns with the definition of dynamic pressure, which is expressed as \rho v^2/2. Omitting this factor would disrupt the scaling relationship with dynamic pressure, leading to incorrect calculations if one were to simply halve the C_d values from tables. The factor ensures that aerodynamic coefficients, such as C_L = \frac{L}{qS}, fit neatly within the framework of flight mechanics. This convenience is particularly beneficial for applications in stability and control. Therefore, the 1/2 factor is crucial for accurate aerodynamic modeling.
damosuz
Why the 1/2 factor in the equation F_{R} = \frac{1}{2}\rho C_{d}A v^{2}? Why not just divide every C_{d} value found in tables by 2 and omit the 1/2 in the equation instead?
The only reason I can think of is that the guy proposing this formula was thinking the force should be proportional to half of one of those things in it(I don't know why though!) and he wants to get sure people have a clue for that. I think the best candidate is the area.
Energy of compressed spring is ##\frac{1}{2}kx^2##. So according to you I will do some magic and replace all k value of spring in every table to k/2.
Now I have an equation ##F=kx##. This is the force exerted by a compressed /elongated spring. If I use the values given in the new table, I will get wrong answer. So I will have to multiply 2 every time I use it. Maybe ##C_d## has other uses and ##C_d## is more commonly used than ##C_d/2##.
In the sense of this equation, the drag scales with dynamic pressure, which is defined as ##\rho v^2/2##. The ##1/2## therefore comes from the fact that the equation contains the dynamic pressure. Without that factor, you could still just divide ##C_d## by two but the scaling with dynamic pressure would be wrong.
Likes FactChecker and Redoctober
Pretty much like boneh3ad said. Having the 1/2 makes the Aerodynamic coefficient wrap up in a nice manner ## C_L = \frac{L}{qS} ## with the dynamic pressure.
It's really convenient this way especially when it comes to application in Flight mechanics, Stability and Control.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
