1-D harmonic oscillator problem
8614smith
Consider a particle of mass m moving in a one-dimensional potential,
V(x)=\infty for x\leq0
V(x)=\frac{1}{2}m{\omega^2}{x^2} for x>0
This potential describes an elastic spring (with spring constant K = m\omega^2) that can be extended but not compressed.
By reference to the solution of the 1-D harmonic oscillator potential sketch and state the form of the valid eigenfunctions, and state the corresponding eigenvalues, for the ground and first excited state.
E=(n+\frac{1}{2})\hbar\omega
https://www.physicsforums.com/attachment.php?attachmentid=23025&stc=1&d=1263339354
Here is the potential sketch
Since the potential V(x)=\infty for x\leq0, The potential at x=0 is infinity. So the wave function at x=0 must equal 0. If it were anything else the particle would have infinite energy. Therefore eigenfunctions must pass through the origin.
http://131.104.156.23/Lectures/CHEM_207/CHEM_207_Pictures/p75a_72gif
From the graph, n=1 and n=3 are the lowest eigenfunctions to pass through the origin.
Ground state eigenfunction n=1 {E_1}=(1+\frac{1}{2})\hbar\omega=\frac{3}{2}\hbar\omega
1st excited state eigenfunction n=3 {E_2}=(3+\frac{1}{2})\hbar\omega=\frac{7}{2}\hbar\omega
Can someone tell me if this is right?
<br /> {E_2}=(3+\frac{1}{2})\hbar\omega=\frac{7}{2}\hbar\omega<br />
I believe you mean E_3=\cdots and not what you wrote. But otherwise, this is correct. This problem is a good example of http://en.wikipedia.org/wiki/Parity_(physics)#Quantum_mechanics".
No, i meant E_2 as i thought it is the 2nd energy level i.e. the 1st excited state, can you tell me why this its not E_2
The reasoning is purely semantics. Since the formula is E_n=\left(n+\frac{1}{2}\right)\hbar\omega, if you have n=3 in the parenthesis, you should have n=3 as the subscript on E. What you should say is (I made a mistake too)
<br /> E^\prime_1=E_3=\left(3+\frac{1}{2}\right)\hbar\omega=\frac{7}{2}\hbar\omega<br />
and you should also write
<br /> E^\prime_0=E_1=\left(1+\frac{1}{2}\right)\hbar\omega=\frac{3}{2}\hbar\omega<br />
because the first equation is the new first excited state and the second equation is the new ground state. If you calculate more levels, you should find that
<br /> E^\prime_n=\left(2n+\frac{3}{2}\right)\hbar\omega<br />
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
