One Resistor, 9V Battery, and Ohm's Law: What is it Resisting?
In a circuit with a 1k ohm resistor connected to a 9 Volt battery, Ohm's Law indicates the current should be 9 mA, not 9 amps. The resistor limits the current flow, preventing it from exceeding this value despite the battery's potential. The term "resistor" may be misleading; it is more accurate to say that a resistor dissipates electrical power rather than simply resists it. The internal resistance of the battery also plays a role in limiting the current output. Understanding the function of resistors in terms of power dissipation rather than resistance can clarify their role in electrical circuits.
Pin Head
Hi,
This may sound a little silly but I have a circuit with 1 resistor which is a 1k ohm resistor
and is connected to a 9 Volt battery.I found the amps using ohm's law I = E/R which equals 9 amps.I have also used a multi-meter to see the resistance and I'm a bit confused a resistor is supposed to resist so what is 1 resistor resisting?
Pin Head said:
Hi,
The current should be 9 mA or 0.009 Amps. using Ohm's law I = E / R,
I = 9 volts / 1000 ohms = 0.009 amps or 9 mA.
The resistor "resists" the current flow being a lot greater than 9 mA.
A 9 volt battery can't supply infinite current because it has internal resistance, but it can supply 0.5 amps for a short time before it goes flat.
Do you have a problem with the naming of resistors? It is just a name. I guess there was a historical reason for naming them like that, but it doesn't matter much as long as you know what device they are talking about
Passing a current through a resistor requires Power.
Rather than saying that a resistor "resists" it's probably better to say that a resistor Dissipates (uses up) electrical power. A voltage V will cause a current I to pass through a resistor R and the resistor will be dissipating VI Watts of power at this time.
Notions of Force and actual Movement tend not, actually, to be very helpful when discussing most aspects of electricity, although they may be attractive ideas, at first sight.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
