Solving a Parabolic Function Near the Minimum of the Morse Potential
The discussion centers on demonstrating that the Morse potential, U = E_0 (1 - exp(-a(r - r_0)))^2, behaves like a parabolic function near its minimum. The key approach involves using a Taylor expansion around the minimum point, r = r_0. At this point, both the potential and its first derivative are zero, while the second derivative is non-zero, confirming the parabolic nature of the function. The approximation U(r) can be expressed as U''(r=r_0)/2 * r^2, indicating its parabolic form. This method effectively shows the desired result near the minimum of the Morse potential.
capslock
I have the equation for the Morse potential, U = E_0 (1-exp(-a(r-r_0))^2. I'm asked to show that near the minimum of the curve the potential energy is a parabolic function. I've tried to play around with the taylor series with no hope! :( :(
Many thanks, James
Many thanks, James
It is indeed just a simple Taylor expansion! Can you show your work?
The potential vanishes at r=r_0 and the derivative of the potential also vanishes at r=r_0. The second derivative does not vanish at that point so you get that U(r) is approximately U''(r=r_0)/2 r^2 so a parabolic function.
Pat
