Is the tangential acceleration of any point on Earth always 0?
  • Thread starter Thread starter 600burger
600burger
Using normal and tangential coord the the tangential acceleration of any point on Earth is 0, correct?
Normal and tengential, coord? I don't quite know what you mean by that, but you are right that since the Earth spins with a constant velocity, there will be no tangential acceleration.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
