Kirk's Mission: Solving for Acceleration Time
  • Thread starter Thread starter fogvajarash
    Acceleration Time
Captain Kirk's mission requires him to cover 870 km in the remaining 3 minutes after traveling for 27 minutes. The discussion focuses on calculating the necessary acceleration time at 20,000 m/s² to achieve this goal. Participants highlight the importance of correctly accounting for the distance traveled during acceleration and emphasize that the initial calculations yielding 0.044 seconds are incorrect. The need for a more realistic acceleration time is noted, with suggestions to verify calculations using established equations. The conversation concludes with a consensus that the initial setup appears correct but requires careful reevaluation of the acceleration value and its implications.
fogvajarash
Captain Kirk is on an important space mission to bring a Klingon ambassador to space outpost 13. He must travel 6000. km in less than 30.0 min, or else war will be declared between the Klingons and humans. After traveling exactly 27.0 min at a steady pace, he sees that there are still 870.0 km left to go.
His ship must then accelerate at 20.000 m/s-2 for how many seconds in order to achieve the desired time?
s = u + at
s = vot + 1/2at2
v2 = u2 + 2as
I've tried separating the motion of the spacecraft in 3 different times. Time 1 is when the spacecraft is at constant speed until 27.0min, time 2 is when the spacecraft starts to accelerate at 20.000m/s-2 and time 3 is when the spacecraft travels at the new constant speed increased by the acceleration. So:
For time 1:
s = vot
Here i found the speed just by plugging in s = 5130000m and t = 1620s.
For time 2 and 3:
s = vot + 1/2at2 + vf(180-t)
180-t as the spacecraft has 3 minutes remaining (180s). I found the vf with the following equations:
vf = v0 + at
I've tried this problem numerous times and I keep getting that the result is 0.044s, but it is wrong.
You are not taking into account the distance traveled while accelerating.
Yes, he must go 870 km in 3 m (870000 m in 180 s). If he accelerates at 20 m/s^2 for T seconds. he will have gone a distance 10T^2+ 3166.67 T and will have achieved a speed of 20T m/s. He must have 10T^2+ 3166.67T+ (20T)(180- T)= 870.
(Knowing Kirk, he will probably dawdle in order to prolong the war!)
@HallsofIvy: He did that into account (at least in the equation s=...). I think you are mixing meters and kilometers here.
@fogvajarash: Here is a quick way to see that 0.044s cannot be right:
With an acceleration of 20m/s^2, accelerating for 0.044s changes the speed just by roughly 1m/s, from 3167 to 3168m/s. To travel the remaining 870km in 3 minutes, the average speed (which is lower than the maximal speed) has to be of the order of 4800m/s. The acceleration time has to be much more than 0.044s.
Please show your work. Your approach looks right, so we have no way to tell what you did wrong if you don't show it.
By the way: m/s-2 does not make sense. ms-2 = m/s2 are correct units for an acceleration.
Crap I meant 20000m/s2 instead of 20.0. Sorry for the mistake
That's still not enough, based on the same estimate.
Again, please show your work.
And that acceleration will crush every living object on the ship.[/size]
I suppose the problem isn't that realistic haha.
Here's my procedure:
There are 870km left, not 730km.
I get as a final result t = 0.0834s. Is this result accurate? (I've changed the 730000 by a 870000).
You can use this value and plug it in your initial equation for s= to check it. It looks reasonable, but I did not check it in detail (WolframAlpha can do that better anyway).
I keep getting an incorrect result for the exercise. Have i made a mistake with setting up the equations? It looks alright to me.
The equations look good.
Are you sure the acceleration is 20000m/s^2? That number looks really odd compared to the other numbers, 20m/s^2 would give more reasonable results.
