1D peak algorithm (correct implementation)
The discussion focuses on the implementation of a 1D peak-finding algorithm in Python, highlighting the need for careful variable naming to avoid conflicts with language keywords. The original code is critiqued for its logic and variable choices, with suggestions to improve clarity and functionality. Participants debate whether the algorithm should find all peaks or just one, noting that while the current implementation has a time complexity of O(logN), finding all peaks would typically require O(n) complexity. The conversation emphasizes the importance of optimizing algorithms while considering the specific requirements of peak detection. Overall, the thread provides insights into coding best practices and algorithm efficiency.
Arman777
Insights Author
Python:
array_values = [[0], [0,0], [1,2], [3,1,2], [1,2,3], [4,6,2,1], [8,9,0,2,1]]
def peakfinder(xarray):
    if len(xarray) == 0:
        print("You entered an empty error !")
        raise ValueError
    if len(xarray) == 1:
        return xarray[0]
    if len(xarray) == 2:
        return max(xarray)
    mid_element_index = len(xarray) // 2
    mid_element = xarray[mid_element_index]
    if mid_element >= xarray[mid_element_index + 1] and mid_element >= xarray[mid_element_index - 1] :
        return mid_element
    elif mid_element < xarray[mid_element_index + 1]:
        return xarray[mid_element_index + 1:]
    else:
        return xarray[ :mid_element_index]
for xarray in array_values:
    while type(xarray) != int:
        xarray = peakfinder(xarray)
    print("The peak value is", xarray)
Is this a "good" 1D peak finder code ? Also I have another problem. In the peak finder case do we have to find all the peak values or just one peak value ?
Also in my code I didnt like `while type(array) != int:`, but I couldn't come up with something clever :(
Thanks
Technology news on Phys.org
I don't know any clever way but did notice the variable name 'array'. The best practices guide will tell you programmers shy away from valid english words when selecting variable names.
The reasoning is that it can introduce some pretty strange behavior in your code if it happens to be a keyword in the language.
There was a recent cautionary story of a guy who got the license plate ‘null’ for his car thinking that plate readers won't be able to track him instead he now got all the ticket infractions for all unreadable plates ie they were assigned the value of null too and so by association he now owned those tickets.
xarray or array1 would be better choices.
Likes StoneTemplePython, Wrichik Basu and Arman777
Thanks I ll be more careful
This became a major problem when I started with Python. In java, for example, I used str for string, which is a keyword in Python. I have several other standard variable names, which turned out to be functions in Python.
My experience was a weird one. Early mainframe Basic interpreters had a function called tst() which I think tested the string values for numeric data (can't remember and can't find via google).
I coded a loop:
for i = 1 to z step 10
and later changed the variable 'z' to something more descriptive 't' so that it read
for i = 1 to t step 10
However, to my great surprise, I got an error saying: "Invalid use of the tst() function expecting '('. "
Apparently, the interpreter removed the spaces during parsing and saw this line instead
fori=1totstep10 and parsed it as for,i,=,1,to,tst ...stop...error...expecting a parenthesis
Likes Wrichik Basu and Arman777
str is a big problem. I think array is generally not a problem, however as @jedishrfu said I shouldn't use it. I was using "sum" in the loops but it was a keyword so that was a problem for me..
I coded a loop:
I guess that's C right ? Its intersting ...
So what about this ? any ideas ?
[CODE lang="python" title="Real recursive version"]array_values = [[0], [0,0], [1,2], [3,1,2], [1,2,3], [4,6,2,1], [8,9,0,2,1]]
print("Error! You entered an empty array ")
raise ValueError
return xarray[0]
return max(xarray)
return mid_element
return peakfinder(xarray[mid_element_index + 1:])
else:
return peakfinder(xarray[ :mid_element_index])
print("The peak value is", xarray)[/CODE]
line 5 empty error --> empty array
If you're looking for the peak value and where its located:
Python:
def findnmax(xarray):
    maxvalue=0
    maxindex=0
    for i in range(len(xarray)):
       if xarray[i]>maxvalue:
          maxvalue=xarray[i]
          maxindex=i
    return (maxindex,maxvalue)
then this code might work.
Python:
    maxvalue=0
    maxindex=0
          maxvalue=xarray[i]
          maxindex=i
I think that's a max value of an array, max can be also peak value but not necessarily.
Thanks !
Okay I got it. Perhaps you can amend the loop in my code to find the case where the value is greater than the maxvalue and the values surrounding it are less and then adding the index of that value to a new array.
My code finds the highest value and thus by the definitions of the project its > the surrounding values.
But what you really want is a list of all values on the hills of the curve.
Great exercise though.
Likes Arman777
I guess in peak find algorithm, finding all the peaks are optional. I mean the algorithm that I use has a O(logN) runtime and definately finds a peak value. We can check each number to find peak points but that would have O(n) time complexity.
The important point is minimize the time complexity. However "if we wanted to find more than one peak or all the peaks" then is it better to use faster version of the algorithm and do some tricks on the array to keep searching or using brute force.
Indeed
