Calculate pH of 2.0e-8M NaOH in Water
  • Thread starter Thread starter gunnar
    Water
To calculate the pH of a solution with 2.0e-8 M NaOH while considering the contribution of hydroxide ions (OH-) from water, the key equations involved are Kw = [OH-][H+] and the charge balance equation [OH-] = [H+] + [Na+]. The process requires rearranging the first equation to express [OH-] as Kw / [H+], which can then be substituted into the charge balance equation. This results in a quadratic equation that can be solved to find the pH, which is determined to be 7.04. For assistance with similar calculations, using tools like BATE for pH and acid-base equilibrium calculations is recommended.
gunnar
there are 2.0e-8 M NaOH in water. I have to calculate the pH of the solution considering the OH from the water. The answear to this is pH=7.04 I know this is calculated with the quadratic equation. what I don't get is how to set this up. I alway get a wrong answear. Can somone help me with this?
Chemistry news on Phys.org
gunnar said:
there are 2.0e-8 M NaOH in water. I have to calculate the pH of the solution considering the OH from the water. The answer to this is pH=7.04 I know this is calculated with the quadratic equation. what I don't get is how to set this up. I alway get a wrong answear. Can somone help me with this?
You have two equations:
Kw = [OH-][H+]
and charge balance:
This is enough to solve the problem, but in case you don't know what to do next:
You have to get rid of [OH-], so rearrange first equation
[OH-] = Kw / [H+]
and use [OH-] in the second equation:
Kw/[H+] = [H+] + [Na+]
That's your quadratic equation.
Try BATE for such (and much more complicated) pH and acid - base equilibrium calculations.
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
Worked out fine. Thanks a lot :smile:
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
