Calculating Maximum River Crossing Distance with Initial Velocity of 30 m/s
To determine the maximum width of a river that can be crossed with an initial velocity of 30 m/s, the initial velocity must be split into horizontal and vertical components using trigonometric functions. The vertical motion equation, y = v_y * t - 0.5 * g * t^2, is used to find the time of flight, where y equals zero when the ball lands. The horizontal distance, or river width, is calculated using the range formula R = v_x * t, where v_x is the horizontal component of the initial velocity. Understanding both components is crucial for solving the problem effectively. The discussion emphasizes the need for a step-by-step approach to clarify the relationship between time and distance in projectile motion.
stressedgirl
If you can hurl a ball so that its initial speed is 30 m/s, what is the widest river it can cross?
v1 = 30m/s
I am not sure with only the one variable given.
Start with a x and y component diagram?
Yes split the inital velocity into vertical and horizontal components.
Now consider vertical motion, when the ball lands on the ground again, the displacement is zero. Use y=vyt_0.5gt2 to get the time for this motion.
Now horizontally the Range (how wide your river is) is given by R=vxt
that 't' in the equation for 'R' is the time for the motion above.
Umm.. I don't understand. How would the 't' answer the question? Wouldn't I need a 'd' since it's asking how wide the river could be?
edit: SOrry I don't really understand what I'm even supposed to draw in the diagrams of the components
Solving for the 't' would get the 'd'.
Draw the 30m/s at an angle θ and split it into vertical and horizontal components.
Can I get something step by step please? I drew the components but I don't get why I even have to have both an x and the y. I just have two sets of axes and a theta angle at 90degrees
You will see why you need it soon.
Did you get your components as
y: 30sinθ
x: 30 cosθ
These are your initial velocity components
Now consider vertical motion: y=vyt-0.5gt2
When the ball hits the other side of the river, y = 0. So solve for 't' and tell me what you get.
