2 dimensional problem with only angle and direction.
  • Thread starter Thread starter freeofwork
    Angle Direction
The discussion revolves around calculating the initial velocity of a cannonball fired at a 45-degree angle to achieve a horizontal distance of 500 meters. Participants clarify that while the horizontal acceleration is zero, the vertical acceleration due to gravity is -9.81 m/s². They emphasize that "downrange" refers to the horizontal distance traveled, not implying a downward angle. The correct approach involves using the range formula, which incorporates both the initial velocity and the angle of launch. Ultimately, the conversation highlights the need to understand the relationship between horizontal and vertical motion to solve the problem effectively.
freeofwork
A cannon fires a cannonball 500.0 mdownrange when set at a 45 degree angle. At what velocity does the cannonball leave the cannon?
Vix=Vi X cosθ
Viy=Vi X sinθ
Tair=viy/a X 2
D=1/2 X at2
D=vt
If i decide to use d=1/2 X at2 will the acceleration be 0? or 9.81? Because isn't the acceleration 0 here because the x component has no acceleration? But that makes no sense at all because the result would have to be 500m. And 9.81 is the y component acceleration. So i not sure.
What does "down range" mean? does it imply that the angle that the cannon shots at is downward?
Im guessing it means that the distance traveled from one point to another is 500m
if that were the case, it would make the prolem very hard to solve. This would be like a UC berkeley type problem. I already tried solving it that way, but there's something I'm missing. Something I can't prove right, but maybe I'm miss reading what this means. So, what does "down range" imply?
ok, well if that's what it means, then it's mUUUUCh easier to solve.
from this equation: Vfy=Viy - gt
in what situation do you think the motion makes Vfy=0m/s?
The thing i am not quite getting is that how is the acceleration 9.81 m/s2. Isnt 500 m only the horizontal direction. Because the parabola created by the initial elocity frm the degree measure would actually have traveled more?
acceleration in the y direction is always -9.81m/s^2 as long as it is in the air, but the acceleration in the x direction is zero. hold on.
500meters is only the horizontal range. that still means there's a height that they don't give you though.
Can anyone else confirm?
think about it. If you launch something at 45 degrees above horizontal, then won't there be a change in height and a change in range? range is the horizontal distance.
So there is a piece missing correct?
you won't need height to find out what they are asking.
I'll give you the formula you need to use, but I'd like that you figure out how it was derived. I'll help you too. :)
Range=V0^2Sin(2theta)/g
SO, as I was saying
Rayquesto said:
SO, as I was saying
I have no idea...
it's when the maximum height occurs, and when half the maximum range occurs.
so, if t=Viy/g at that point, then 2Viy/g=t for the entired motion to take place and when range exists.
And then distance=Vix(t)
so, (range)=vix(2viy/g)
vix=vi(costheta)
viy=vi(sinetheta)
range=2vi^2costhetasintheta/g
range=vi^2sin2theta/g
