What is the diagram for a particle attached to 2 elastic light springs?
A particle of mass 0.8 kg is attached to two identical elastic springs, each with a natural length of 1.6 m and a modulus of elasticity of 16 N, positioned between two points A and B that are 4 m apart. The particle is held at point C, which is 2.5 m from point A, creating a straight line configuration of points A, B, and C. When the particle is released from rest, the springs exert tension in different directions due to the displacement from their natural lengths. The discussion seeks clarification on how to diagram this setup and the forces acting on the particle. Understanding the tensions in the springs is crucial for solving the problem effectively.
aurao2003
Hi
I can't seem to get a diagram for this question. Can anyone help and also please explain the subsequent diagram. This is the question. A particle of mass 0.8kg is attached to the ends of 2 identical light elastic springs of natural length 1.6m and modulus of elasticity 16N. The free ends of the springs are attached to 2 points where points A and B which are 4m apart on a smooth horizontal surface. The point C lies between A and B such that ABC is a straight line and AC = 2.5m. The particle is held at C and then released from rest.
My textbook has tensions acting in different directions. Can anyone explain? Thanks
Consider two parallel walls at a distance of 4m apart. put a mass of 0.8kg 2.5m from one of the walls. now attach springs b/w the mass and each of the walls.
got it?
Thanks. I like the analogy. I will get back to you.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
