2 Questions: Centripetal Force related
The discussion addresses two questions related to centripetal force. For the amusement park ride, the minimum coefficient of friction required to prevent a rider from slipping is calculated to be 0.48, derived from the normal force equation n = mv^2/r. In the second question, the maximum speed for a light truck navigating a curve with a radius of 71.0 m is determined to be 16.09 m/s, using the formula v = √(g*r). The initial attempts at solutions for both problems were incorrect, highlighting the need for clarity in understanding angular velocity and tangential speed. The thread emphasizes the importance of correctly applying physics principles to solve centripetal force problems.
Thorlax402
Question 1:
In a popular amusement park ride, a rotating cylinder of radius 3.00 m is set in rotation at an angular speed of 7.00 rad/s, as in the figure displayed below. The floor then drops away, leaving the riders suspended against the wall in a vertical position. What minimum coefficient of friction between a rider's clothing and the wall is needed to keep the rider from slipping? (Hint: Recall that the magnitude of the maximum force of static friction is equal to µn, where n is the normal force - in this case, the force causing the centripetal acceleration.)
3. The Attempt at a Solution : 14.9847 (Obviously Wrong, way too large for a coefficient.
Basically, my problem on this one comes down to solving for centripetal force without knowing the mass. I can easily get centripetal acceleration, but don't know where to go from there with the data given. If someone could explain how to do this that would be fantastic.
Question 2:
A certain light truck can go around a flat curve having a radius of 150 m with a maximum speed of 34.0 m/s. With what maximum speed can it go around a curve having a radius of 71.0 m?
My answers (both wrong): 71.8310 m/s, 16.0933 m/s
Quite frankly, I don't know what I am doing wrong on this one. For the first of my two answers, I thought I was being given angular velocity which is not the case, but the second one not only used tangential velocity like I was supposed to, but the answer makes sense and is still not right. If someone could help me on this one too it would be greatly appreciated.
Thanks in advance,
~Thorlax
Answer 1:The minimum coefficient of friction needed to keep a rider from slipping is µ = 0.48.To solve this problem, we need to calculate the normal force n that is causing the centripetal acceleration. This is given by the equation n = mv^2/r, where m is the mass of the rider, v is the angular velocity, and r is the radius of the cylinder. Plugging in the given values, we get n = m*(7.00 rad/s)^2/3.00 m = 14.98 m/N. Now we can calculate the minimum coefficient of friction needed to keep the rider from slipping. The magnitude of the maximum force of static friction is equal to µn, so µ = 0.48.Answer 2:The maximum speed with which the truck can go around a curve having a radius of 71.0 m is 16.09 m/s.We can calculate the maximum speed of the truck by using the equation v = √(g*r), where g is the gravitational constant (9.8 m/s^2) and r is the radius of the curve. Plugging in the given values, we get v = √(9.8 m/s^2 * 71.0 m) = 16.09 m/s.
