drl
- 31
- 2
In the 2 slit experiment , what would be the result if we put a dedector on both slits? would we get an interference patern?
Ok I'm not too sure about polarization. I would assume that polarisations of light which are not in line with each other would not interfere.drl said:Where my problem comes in is if a polarizer is placed at each of the 2 slits and the polarizers are parallel we get an interference pattern. If the polarizers are in crossed position , the interference pattern disappears. I would have assumed that if we used detectors at both slits we would have obtained the same result. please explain.
English is ambiguous here. Do you mean two detectors, one on each slit? Or do you mean one detector that spans both slits?drl said:what would be the result if we put a dedector on both slits?
How is it possible to have individual photons pass through slits and have two separate detectors and at the same time have no clue which went through which? The act of knowing something went through something allows you to figure out where it went.Khashishi said:English is ambiguous here. Do you mean two detectors, one on each slit? Or do you mean one detector that spans both slits?
If the detector can provide "which way" information, then it will destroy the interference. But if the detector counts the particles that pass either slit without telling which slit the particles pass through, then it can preserve the interference, provided it is not possible in principle to tell which slit they passed through.
vanhees71 said:it's very clear that then you get the full-contrast 2-slit interference as if there where no polarizers (of course with a factor 1/2 reduced intensity, because half the photons are absorbed by the polarizers). Of course then you don't gain any which-way information whatsoever. For 90-degree relative orientation your interference pattern is completely gone (and you gain complete which-way information).
vanhees71 said:S. P. Walborn, M. O. Terra Cunha, S. Pádua, and C. H. Monken, PRA 65 033818 (2002)
You'd have to provide a clear mathematical definition of what you mean by the wave function "at that slot" and how it is that anything can be "incompatible with" anything else when there's only one wave function involved.drl said:wave function at that slot is altered to the extent that it becomes incompatible with the unaltered wave function from the other slot to achieve an interference pattern?
drl said:It seems to me that a single wave function in superposition goes to the 2 slits.where the detector at one of the slits alters the wave function so that it is different from the other wave function at the other slit.I assume that in order to get an interference pattern the wave functions at both slits have to be the same. The crossed polarizers at the slits indicates there is . no interference pattern until the wave functions are the same, as when an eraser is used. Hope I don't annoy you!
drl said:O.K. It seems to me that that the idea that you cannot transmit whichway information has some sort of mystical origin which I find difficult to accept. Again, could it be that any attempt to find whichway information alters the wave function where the detector is used so that it is not compatible (out of phase) with the wave function from the other slit. At rate, if it has not been attempted as yet, why not give a detector at both slits a try..
As PerOK has said you have a misconception about this situation. In quantum mechanics, if there is more than one way for something to happen then all the ways must be taken into account in calculating probabilities of outcomes. Combining amplitudes can cause interference if the parts remain coherent.drl said:O.K. It seems to me that that the idea that you cannot transmit whichway information has some sort of mystical origin which I find difficult to accept. Again, could it be that any attempt to find whichway information alters the wave function where the detector is used so that it is not compatible (out of phase) with the wave function from the other slit. At rate, if it has not been attempted as yet, why not give a detector at both slits a try..
What do you think will happen if there is a detector at both slits ? Remember that the more accurately the detector can locate the particle the more will be the decoherence.drl said:O.K. Perok says "Do you really think that in almost 100 yrs. no one has thought to put a detector at both slits. Hey, that was my very first question in this thread." If it was done what were the results? Perhaps my volcabulary was off and the further question should have been if the detector could alter that part of the wave function crossing the detectors slit so that its waves were no longer coherent with the wave function going thru the other slit! Somehow I feel as if I`m missing something or I`m not getting across.
You're still saying things like "the wave function going through the other slit" and "that part of the wave function crossing the detectors slit". But that's not how it works. The wave function is a function, a mathematical formula into which you plug four input numbers (time and position along each of three spatial dimensions) to calculate a single complex output number. Talking about it moving or going through a slit makes no more sense than talking about hitting the quadratic formula with a hammer, or boiling Newton's third law in a kettle, or... You get the idea.drl said:Perhaps my volcabulary was off and the further question should have been if the detector could alter that part of the wave function crossing the detectors slit so that its waves were no longer coherent with the wave function going thru the other slit! Somehow I feel as if I`m missing something or I`m not getting across.
It was, and "What happens?" was answered by @Khashishi in post #6 of the thread.drl said:Hey, that was my very first question in this thread.
Nugatory said:You're still saying things like "the wave function going through the other slit" and "that part of the wave function crossing the detectors slit". But that's not how it works. The wave function is a function, a mathematical formula into which you plug four input numbers (time and position along each of three spatial dimensions) to calculate a single complex output number. Talking about it moving or going through a slit makes no more sense than talking about hitting the quadratic formula with a hammer, or boiling Newton's third law in a kettle, or...
There is nothing mystical about the interference. In quantum mechanics all the possible ways of something happening have to be included in the outcome, by adding amplitudes. It is all predicted and explained by quantum theory. Loss of the interference is caused by decoherence which results from partial or full position detection at the slits.drl said:Getting confused Let's put it this way.There has to be 2 coherent waves each of which goes thru one of the slits to get an interference pattern. Some how the particle creating these coherent waves can only go thru one of these slits at any time and we still get an interference pattern. It is only when we try to detect the which way that it took that we get a wave function collapse. So again I`m asking if this a result of some mystical thinking that some how which way information is forbidden or can it be the result of the detectors effect on the wave passing thru to alter its coherency to the wave at the other slit? Sorry to be a pain. Thanks for your efforts.
The purpose of putting a detector on both slits in the 2 slit experiment is to observe and measure the behavior of particles passing through the slits. This allows us to better understand the phenomenon of interference and how particles behave as waves.
The presence of a detector on both slits changes the outcome of the 2 slit experiment. It eliminates the interference pattern and creates two distinct bands of particles on the screen, as the detectors collapse the wave function of the particles and force them to behave like particles rather than waves.
Yes, the results of the 2 slit experiment can be explained without using a detector on both slits. This is known as the double-slit experiment without detectors, and it demonstrates the wave-like behavior of particles. However, the presence of detectors helps to explain the specific behavior of particles passing through the slits.
The Heisenberg uncertainty principle states that it is impossible to know both the position and momentum of a particle with absolute certainty. In the case of the 2 slit experiment, the presence of detectors allows us to measure the position of the particles, but it also introduces uncertainty in their momentum, which affects the outcome of the experiment.
Yes, there are other factors that can affect the results of the 2 slit experiment when using detectors on both slits. These factors include the type of particles being used, the distance between the slits and the screen, and the accuracy and sensitivity of the detectors themselves.
