Electric dipole's maximum angular velocity
superamazinPI
Consider an electric dipole located in a region with an electric field of magnitude \vec{E} pointing in the positive y direction. The positive and negative ends of the dipole have charges +q and -q, respectively, and the two charges are a distance D apart. The dipole has moment of inertia I about its center of mass. The dipole is released from angle \theta, and it is allowed to rotate freely.
What is \omega_{max}, the magnitude of the dipole's angular velocity when it is pointing along the y axis?
dipole moment p= qd
\vec{\tau}=\vec{p}X\vec{E}
U= -\vec{p} \cdot\vec{E}
I attempted to use energy, but I am not sure how to do it correctly - does potential energy equal kinetic? is the potential energy the one described in the above equation?
dipole in a E field gives torque, torque is a force and can then be related to moment of inertia and angular acceleration
You can use your expression for U and (1/2)I\omega^2 for the KE.
