Stargazing Building a telescope ( from another one )
The guide from Apogee Inc. is deemed acceptable for building a telescope, but it may not provide accurate measurements for all components. Specifically, the guide uses a different focal length (f10) compared to the user's f4, 4.5" mirror, which has a focal length of 500 mm. As a result, the telescope tube should be approximately half a meter long, rather than following the guide's dimensions. Users are advised to adjust the plans accordingly to ensure proper alignment and functionality. Following these adjustments will help successfully complete the telescope build.
vincentm
Hello,
I'm looking to build my first telescope from http://www.apogeeinc.com/product.asp?itemid=766 (PDF file). My question is this, is this a suitable guide in doing so? If not what steps should i take to successfully complete this task?
Astronomy news on Phys.org
I like it. It's consistent with advice from reputable sources.
vincentm said:
Hello,
It's OK as a guide but you won't be able to use any of plans directly for measurements of length. Your mirror is an f4, 4.5" 500 mm fl. The guide uses one of the same diameter but with a focal length of 1140 mm (f10 mirror).
The tube you should build for this mirror from the Bushnell scope will only be around half a meter long.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
