What type of solar panel is needed to power a 6A desk fan?
To power a 6A desk fan using solar energy, a significant solar panel size is required due to the fan's high power demand, estimated around 750W. Directly connecting the fan to a solar panel is impractical because of the need for voltage conversion from DC to AC, which results in power loss. A more efficient solution is to use a smaller DC fan with a DC-DC converter to match the solar output. The efficiency of solar panels, typically 10%-15%, and conversion losses must be considered when calculating the necessary panel area. Ultimately, the user decided against the large solar setup and opted to use conventional wall power instead.
marzelvane
Hi Eureka
I'd like to make a solar powered fan, but don't know how to convert the power from a solar panel to the fan. Perhaps I don't have to do anything, I can just hook it up?
Requirement: If the sun is out the fan should be running. At night time the fan should not run. In other words, I'd prefer to not use batteries.
Here are the current specs:
I bought a small desk fan:
http://www.acehardware.com/product/index.jsp?productId=2254749
There is a small plastic housing (about 1inch by 1inch) that has four wires attached (looks like 2 going in and 2 going out). On this housing it says:
6A 120 VAC
3A 240 VAC
I have not purchased a solar panel yet. What type of solar panel do I need to power this thing (i.e. power rating, voltage, amps, etc). It seems to me like 6A is a lot...
In my head I picture: mounting a solar panel outside, running the leads directly to the fan (but bypassing the fan's transformer) and then the fan will just run directly off the solar panel.
Thanks for any help everyone.
-m
Calculate the power requirement for that fan. P = V * I. What do you get? Something around 1 horsepower with those numbers ( 1hp = 750W approx. ). That's a lot of power to be getting off of a small solar panel. You will need several square meters of solar panel to power that fan -- is that really what you want?
Also, you will lose power in the conversion from the DC output of the solar cells to the 110Vrms input for the fan. A better solution would be to use a DC fan (preferably smaller), and use a DC-DC converter to convert between the solar cell output and the fan input.
Max insolation at noon is about 1kW/m^2, and simple solar cells are 10%-15% efficient, IIRC. You can do the math to figure out how many square meters of solar panel you need for powering various devices. Remember to factor in the low efficiency of solar cells, and multiply in about 85% for the DC-DC (or lower for DC-AC) conversion...
Thanks for the reply! I was worried about that being the case...there is no way I want a solar panel that large lol. I'll just plug this damn thing in the wall.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
