Trigonometry or components to find the displacement
To determine Bob's displacement back to his starting point, the discussion emphasizes using trigonometry to break down his movements into components. Bob first walks 360 m south, jogs 490 m southwest, and then walks 360 m at 35 degrees east of north. Participants suggest drawing a diagram and calculating the x and y components for each segment of his journey, ensuring to account for direction correctly. The importance of visualizing each trajectory as a right triangle is highlighted, which aids in accurately applying the sine and cosine functions to find the resultant displacement. Ultimately, clarity in setting up the components and applying the Pythagorean theorem is crucial for solving the problem correctly.
ScullyX51
1. Homework Statement :
Bob walks 360 m south, then jogs 490 m southwest, then walks 360 m in a direction 35 degrees east of north.
Use either trigonometry or components to find the displacement that will return Bob to his starting point by the most direct route. Give your answer as a distance.
Express your answer using two significant figures.
3. The Attempt at a Solution :
I drew a diagram and got the components of each.
360(cos35)(sin35)
490(cos35)(sin35)
For the components I got:
(0,360)
(401.38,281.05)
(294.89,206.49)
Then I added the x's and y's and used pythagoreum theorem, and I got d=1096.87, which isn't correct. What am I doing wrong??
y components = -360m + -490cos(45) + 360cos(35)
x components = 0 + -490sin(45) + 360sin(35)
Then use pythagoras.
Make sure you get positives and negatives correct depending on which way he's travelling.
Why did you do 360(cos35)(sin35) ? and 490(cos35)(sin35) ?
You need to imagine each trajectory as a right angled triangle with the two short sides along the North/South and East/West planes and the hypotenuse being his travel path.
You know all of the angles ie. 35 degrees and SouthWest = 45 degrees west of south.
Thank you that worked! I was confused about what to use for the components of each vector. I did that because I thought to get the components I would multiply the length times the x and y components of each. (the sin and cosine). I don't know, I am really lost with this chapter.
