Solving for Magnetic Field Strength given Induced voltage in a coil
To solve for the magnetic field strength given the induced voltage in a coil, Faraday's Law is applied, where the induced electromotive force (emf) is related to the rate of change of magnetic flux. The setup involves a coil placed in a Helmholtz pair with a 20V AC supply at 60Hz, and the induced voltages are recorded using an oscilloscope. The derived equation for magnetic field strength is B = emf/(2*pi*r^2*f), where r is the radius of the coil and f is the frequency. The approach involves integrating the relationship between emf and the changing magnetic field. Clarification is sought on the correctness of this method for calculating the magnetic field strength.
under_par_00
This is part of a lab I did, I am working on the writeup now. We placed a coil of wire inside of a Helmholtz pair, with 20V of 60Hz AC through the Helmholtz pair. The coil inside was connected to an oscilloscope and the induced voltages were recorded. I now need to solve for the strength of the magnetic field as the coil was moved along the axis of the Helmholtz pair.
Period = 1/frequency T=1/f
Faraday's Law emf = -d/dt (magnetic flux)
Faraday's Law: emf = dB/dt * 2*pi*N*r^2 (area is constant, N is number of loops, B is changing)
dB = emf/(2*pi*r^2) *dt
integrate both sides
B = emf/(2*pi*r^2*f) (f is frequency of current through the Helmholtz pair)
Is this correct? Can I do this?
can anyone help?
