Effect of mass and springs on the damping of mass spring system
In a mass-spring system, reducing the mass by 25% and the spring stiffness by 50% will lead to a decrease in the damping factor, but quantifying this change is complex. The critical damping ratio, represented by the equation ζ = c / (2√(km)), indicates that both mass and stiffness alterations affect damping. The discussion highlights that the final displacement will increase in the modified system due to the greater reduction in stiffness compared to mass. Experimental tests have shown a reduction in ζ of about 50%, but a mathematical proof is sought to explain this outcome. Understanding the relationship between kinetic and potential energies may aid in deriving the necessary proof.
Zaid
If I have mass-spring system with certain damping factor, what is the expected reduction in the damping if the mass is reduced by 25% and the spring stiffness by 50%? It is clear that the damping will decrease but how much? can anyone helps me in that?
No body helped in that. I really need a help
Does using kinetic and potential energies help in that? Any idea?
The critical damping ratio of a system is often used to compare system damping to that which would result in a critically damped case (i.e. quickest settling time, no overshoot). This is given by:
\zeta = \frac{c}{2 \sqrt{k m}}
where stiffness is k, mass is m and damping constant is c.
You can see the effect that this has on oscillation amplitude as follows. Consider the variation of amplitude of an underdamped single degree of freedom mass-spring-dashpot system (bit of a mouthful) with time:
x(t) = e^{-\zeta \omega _{n} t} ( A cos(\omega _{d} t) + B sin(\omega _{d} t))
where:
\omega _{d} = \omega _{n} \sqrt{1-\zeta^{2}}
A = x(0)
B = \frac{1}{\omega _{d}}(\zeta \omega _{n} x(0) + x^{.}(0))
(last term is supposed to contain first derivative w.r.t. time)
A good resource to show how this varies with different values of mass, stiffness and damping constant can be found here.
Thank you Timmay
What I have is reduction in mass and stiffness but the damping c will decreases accordingly. So zeta and c are not fixed and unknown.
Zeta can be found if the initial displacement, the final displacement and the time difference. Therefore for both cases if we started with same displacement, the final displacement in the second case (reduction 50% in stiffness and 25% in mass) will be larger as the reduction in mass is less than the reduction in stiffness. if we can find the increase in the final displacement of the second case in compared with the final displacement in the first (original)case, the problem is solved. Potential and kinetic energies may help, guess. I need furtrher help in that from you Timmay and other colligues.
If you can measure the variation of displacement with time of your system for unforced damped vibrations (again I'm assuming underdamped) then you could use the log decrement method.
If the system parameters do not change within a single test, then the ratio between successive peaks or troughs (local maxima and minima) will remain constant. It can be shown that for any two adjacent local maxima:
\frac{x (t _{m})}{x (t _{m+1})} = e^{ \frac {2 \zeta \pi}{\sqrt {1- \zeta^{2}}}
The log decrement ( \delta ) is then equal to:
\delta = ln\frac {x (t _{m})}{x (t _{m+1})} = \frac {2 \zeta \pi}{\sqrt{1- \zeta^{2}}}
You can calculate and rearrange to find \zeta for each test, and then express in terms of the first equation in the original post to show the effect on damping constant for each set of conditions. I guess from your last post that one of these two steps should satisfy you.
Thank you timmay
I've done the two tests experimentally and I got reduction in zeta to bout 50%. However I'm looking for a mathematical proof explaining this reduction.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
