2D completely inelastic collision question
In the discussion about a completely inelastic collision between Andy and Sam on toboggans, participants worked through calculating the final speed and direction after they collide and lock hands. They emphasized the importance of breaking down the velocities into x and y components, noting that Andy's direction is positive in the y-axis while Sam's is negative. The correct equations were established, leading to the final speed of 7.8 m/s at an angle of 2.5 degrees below the horizontal. Clarifications were made regarding the interpretation of angles in relation to the horizontal axis. The final consensus confirmed that the calculations aligned with the expected results from the textbook.
Hoodoo
Andy (mass 92 kg) and Sam (mass 75 kg) are both on toboggans (each toboggan has a mass of 4.6 kg) traveling on a crash course towards each other. Just as they hit, they lock hands so they move together as one. What is their new speed? In what direction do they travel?
mA = 96.6 kg
vA = 8.8 m/s at 8.7 degrees above horizontal (headed +x direction)
mS = 79.6 kg
vS = 6.7 m/s at 7.3 degrees below horizontal (headed +x direction)
mA + mS = 176.2 kg
vf = ?
mAvA + mSvS = mAvA' + mSvS'
Tried finding x and y components and unsure what to do next.. since Andy is headed southeast, do I make that y-component negative? Am I combining too much into these equations? I am so confused with these questions where 2 things are moving at the same time or at non-right angles to each other. Can someone break these problem types down for me so that I have a step by step approach to them? I end up with equations and have no idea how to follow through. Here, I have 2 equations and 2 unknowns in each equation. I don't know what to do next or if this is even correct.
(96.6)(8.8 cos 8.7) + (79.6)(6.7 cos 7.3) = (176.2)(vfcosσ)
7.77 = (vfcosσ)
(96.6)(8.8 sin 8.7) + (79.6)(6.7 sin 7.3) = (176.2)(vfsinσ)
1.11 = (vfsinσ)
Hoodoo said:
mA = 96.6 kg
mS = 79.6 kg
mA + mS = 176.2 kg
vf = ?
Andy is headed North-East, so the y component of its velocity is positive. But Sam travels to South-East, use negative sign with the y component of his velocity.
7.77 = (vfcosσ)
(96.6)(8.8 sin 8.7) - (79.6)(6.7 sin 7.3) = (176.2)(vfsinσ)
[STRIKE]1.11 = (vfsinσ)[/STRIKE]
Use the negative sign in the second equation and then you get a numerical value for (vfcosσ) and (vfsinσ).
If you square these equations and add them, the result is vf2.
If you divide them you can get the the tangent of angle σ.
ehild
Andy is headed south-east and Sam is heading north-east.
Alright, so I got:
-0.3452/7.77 = vfsinσ/vfcosσ
-0.0444 = tanσ
-2.5 degrees for σ
Does that imply it's below the horizontal?
Also, followed the instructions on adding the equations together and then squaring. It wasn't until I got to the end that I remembered that sin squared + cos squared = 1 so I wasn't realizing that they would eventually go away.
So vf = 7.8 m/s at 2.5 degrees below the horizontal
My problem with this question was not remembering my trig! Thanks for opening up my brain.
Hoodoo said:
Alright, so I got:
vfsinσ=0.3452/7.77, positive. So is σ.
ehild
Answer from the text agrees with what I got. You are picturing them heading in the wrong directions. They are both heading towards each other. Andy is headed south-east (-y) and Sam is headed north-east (+y). The -2.5 degrees tells me that it's below the horizontal which is what my text tells me.
Is that wrong?
Well, I think "above" and "below" horizontal refers to the direction of velocity vectors, and not to arrows representing the velocities. So "8.7° above horizontal" means a positive angle enclosed with the +x axis. "7.3° below horizontal" is a negative angle with respect to the positive x axis. I might be wrong.
ehild
