2D Kinematics: astronaut ballplayer
The discussion focuses on solving kinematic problems related to an astronaut throwing a ball. For maximum range, the optimal angle is confirmed to be 45 degrees. The required speed to achieve the maximum range of 14 meters is questioned, with an initial calculation of 14.54 m/s deemed incorrect. The distance the ball can be thrown on a planet with a different gravitational acceleration is calculated, yielding a distance of approximately 9.81 m. The maximum height reached by the ball on this new planet remains unresolved, highlighting a need for clarification on the calculations involved in parts B and D.
dharmank
An astronaut in his space suit can throw a ball a maximum distance dmax = 14 m on the surface of the earth.
a) For a given speed of the ball, what angle to the horizontal q (in degrees) will yield the greatest range?
q = 45 OK
b) If the ball is thrown at this same angle q, what speed will produce this greatest range (14 m) ?
v = 14.54 m/s NO
c) How far can he throw the ball on a planet where g1 = 18 m/s2?
xp =9.81*14/18 m OK
d) What height will the ball reach on this "maximum range" trajectory? (on the planet where g1 = 18 m/s2)
hmax = 12 m NO
HOW DO YOU SOLVE PART B AND D?
An explanation of the process would be great
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
