Object Launched from Origin: Time to Reach the Roof
In summary, the "Object Launched from Origin: Time to Reach the Roof" experiment involves measuring the time it takes for an object to reach the roof of a building when launched from the ground. To perform this experiment, a ruler or measuring tape, a timer or stopwatch, and an object to launch are needed. The procedure involves measuring the height of the building, launching the object towards the roof, and timing its journey. Factors that can affect the time include the weight and shape of the object, air resistance, and the force applied during launch. This experiment helps to understand principles of projectile motion, gravity, free fall, and the effects of different factors on the motion of objects in the air.
nando94
33
An object is launched from the origin with a velocity of 20 m/s at an angle of 30 degrees above the x axis. The object lands on a roof that is 4 meters high. What is the time when the object hits the roof?
a) 1.11 s
b) 1.27 s
c) 1.33 s
d) 1.49 s
e) 1.67 s
I did 20 (sin(30)) = 10 m/s. Then used the equation
vf = vi + at
0 = 10 - 9.8t
t = 1.02 s
What am I doing wrong.
vf is not 0, for starters. Consider using the fact that yi=0 and yf=4.
1. What is the "Object Launched from Origin: Time to Reach the Roof" experiment?
The "Object Launched from Origin: Time to Reach the Roof" experiment is a simple physics experiment where an object is launched from the ground and its time to reach the roof of a building is measured.
2. What materials are needed for this experiment?
To conduct this experiment, you will need a ruler or measuring tape, a timer or stopwatch, and an object to launch, such as a ball or toy car.
3. How do you perform this experiment?
First, measure the height of the building from the ground to the roof. Then, stand at the base of the building and launch the object straight up towards the roof. Use the timer to measure the time it takes for the object to reach the roof. Repeat the experiment multiple times and take the average time for more accurate results.
4. What factors can affect the time it takes for the object to reach the roof?
The time it takes for the object to reach the roof can be affected by various factors such as the weight and shape of the object, air resistance, and the force applied when launching the object.
5. What can we learn from this experiment?
This experiment demonstrates the principles of projectile motion and the effects of gravity on objects. It also helps to understand the concept of free fall and how different factors can affect the motion of objects in the air.
