2nd Order In-Homogeneous Particular Solution?
raaznar
Did it :)
Yes, the characteristic equation is r^2+ 4r+ 3= (r+ 3)(r+ 1)= 0 which has roots r= -1 and r= -3 so the general solution to the associated homogeneous equation is Ae^{-3x}+ Be^{-x}.
For 2e^{2x}cos(x) try e^{2x}(Ccos(x)+ Dsin(x). For ##3xe^{-4x}##, try e^{-4x}(Ex+ F). For 3, try G.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
