What Initial Speed Must Bruce Throw the Bagels for Henrietta to Catch Them?
To determine the initial speed Bruce must throw the bagels for Henrietta to catch them, calculations show that Henrietta travels 18.75 meters down the sidewalk while Bruce throws the bagels 7.5 seconds after she passes below the window. The time it takes for the bagels to fall 56 meters is calculated to be approximately 3.38 seconds. Using this time, the required horizontal speed of the bagels is found to be 5.55 m/s. However, there is confusion regarding the total distance Henrietta covers during the bagel's flight, which needs to be added to her initial distance from the building. Clarification is needed on how to accurately calculate both the total distance Henrietta travels and the horizontal velocity of the bagels.
R.Dahl
question reads as follows...
Henrietta is going off to her physics class, jogging down the sidewalk at a speed of 2.5 m/s. Her husband Bruce suddenly realizes that she left in such a hurry that she forgot her lunch of bagels, so he runs to the window of their apartment, which is a height 56.0 m above the street level and directly above the sidewalk, to throw them to her. Bruce throws them horizontally at a time 7.50 s after Henrietta has passed below the window, and she catches them on the run. You can ignore air resistance.
With what initial speed must Bruce throw the bagels so Henrietta can cath them just before they hit the ground?
Where is Henrietta when she catches the bagels?
First I determined how far down the sidewalk Henrieta would be by d=vt (d=2.5*7.5=18.75).
Then I used the equation [y=y_0 + v_0y - 1/2*g*t^2], substituting into get [0=56 - 4.91*t^2], I found time t to be 3.38s,
and finally using the equation [x=x_0 + v_0x*t] I substituted [18.75 = v_0x*3.38] and solved for v_0x as 5.55 m/s. I am at a loss as to what I did wrong.
Secondly for the second part of the problem which asks how far from the building the woman is when she catches the bagel would that answer be found by d=v*t, based on my understanding of the problem we are basing the speed of the bagel on how far it needs to be thrown before striking the ground.
I've reworked it several times but it keeps telling me the answer is wrong.
3.38 s is the total time of flight.
Henrietta is 18.75 m from the house when the flight starts.
How much further has she traveled during the flight time ?
What is her distance now from the house ?
How far have the bagels traveled in this time ?
So what is the (bagel's) horizontal velocity ?
thank you for your help
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
