Troubleshooting Electromagnet Design for Telegraph Key and Sounder
  • Thread starter Thread starter Cspeed
    Electromagnet
The discussion focuses on troubleshooting a telegraph key and sounder design that utilizes a ferromagnetic nail as an electromagnet. The creator is struggling to generate sufficient magnetic attraction with their current setup, using either AA or D batteries, and is not achieving the desired sound effect. Suggestions include increasing the number of wire turns on the nail, using a higher voltage power source, and considering alternative ferromagnetic materials like screws for better performance. The importance of using appropriate magnet wire and ensuring a good magnetic circuit is emphasized, with a recommendation to explore a horseshoe magnet design for improved results. Implementing these changes is expected to enhance the functionality of the telegraph sounder.
Cspeed
I'm trying to build a telegraph key and sounder. The sounder that I have designed (well, saw online) is a metal nail (which is ferromagnetic) with at least several dozen (maybe 200+) turns of wire around it. When a current is on the wire, the nail should become an electromagnet, and then pull down some kind of ferromagnetic metal strip, creating a sound. Upon being released, the strip bounces back up (maybe using a rubber band) to clang against something else.
My issue: Using either two AA batteries or two D batteries, I can't get the nail to attract much of anything, not even close to making a sound. I haven't found a good metal strip yet, but even paper clips barely get attracted to the nail. If a compass is close enough, it will detect the magnetic field. Any suggestions? Is it possible that the nail isn't very ferromagnetic, or is there something better to use? Thanks for any help.
You need either more turns or more current. Try a 6V lantern battery or a 12 V Pb-acid alarm battery.
You might increase the diameter of your core. Try a screw, for example, maybe 1/4-20 x 2", wrapped with 1 layer of electrical tape so the threads don't bite into the wire. Are you using small gauge (around 24 AWG) magnet wire? (Magnet wire has a clear coating instead of thick plastic insulation, so you can wind many turns in a small radius.) Two dozen turns won't do the job--try hundreds. You should get action!
I probably have 100-200 turns of 28 AWG, insulated. Does the length of the nail matter? It's about 0.5 cm diameter, 6cm length.
Here is a nice telegraph sounder design:
http://www.sfu.ca/~achanne/projects/Telegraph%20Sounder/
There are two solenoid coils wound around small bolts, with a piece of iron connecting the bottoms of the two bolts, to create a horseshoe electromagnet. This horseshoe magnet design with two coils is a much better magnetic circuit than a single nail.
Wow, that's a great guide. I'll go ahead and try that out then.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
