A Different kind of kinematics problem
A motorcycle daredevil aims to jump over burning school buses and land on a ramp sloping down at 20 degrees. To ensure a safe landing without bouncing, the ramp must be tangent to his trajectory at the point of contact. The horizontal and vertical distances from the launching platform to the ramp's edge need to be calculated based on the motorcycle's initial speed of 40 m/s and the trajectory's characteristics. The key is to determine where the y-component of the velocity equals 40 times the tangent of 20 degrees. This problem highlights the importance of precise calculations in kinematics for successful stunt execution.
numberjuan412
A "Different" kind of kinematics problem..
A motorcycle daredevil wants to set a record for jumping over burning school buses. He has hired you to help with the design. He intends to ride off a horizontal platform at 40m/s, cross the burning buses in a pit below him, then land on a ramp sloping down at 20degrees. It's very important that he not bounce when he hits the landing ramp because that could cause him to lose control and crash. You immediately recognize that he won't bounce if his velocity is parallel to the ramp as he touches down. This can be accomplished if the ramp is tangent to his trajectory and if he lands right on the front edge of the ramp. There's no room for error! Your task is to determine where to place the landing ramp. That is, how far from the edge of the launching platform should the front edge of the landing ramp be horizontally and how far below it? There's a clause in your contract that requires you to test your design before the hero goes on national television to set the record.
V_{xo} = 40m/s
V_{yo} = 0m/s
I understand that I must find the point on the trajectory where the line tangent to the point is 20^{o}. But how exactly do I figure that out?
I understand what it takes to solve this problem, my issue is how I figure out which point on the trajectory where the line tangent to the point is 20^{o}.
The angle depends on the x and y components of the velocity at that point. Assuming no air resistance, the x-component is fixed, while the y-component can be determined in terms of other variables such as time using the standard kinematics equations.
The velocity on the x-direction is always constant, so I have to find the point where the velocity in the y-direction is 40tan20? err -40tan20...
I guess it is...wow this was simpler than i thought haha.
That's all I needed to know.
Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
